It is possible to connect this LCD TFT screen to the raspberry 3 model B please ? I don't understand the schematic for SPI connection. Any help is welcome thank you.
I have follow this answer but it does not help me.
Probably this library can help me for the driver, but I do not know how to connect that.
-products
-vma412_diagram
UPDATE PROGRESS: enter image description here vma412_diagram / datasheets - ILI9341
enter image description here data-sheet 74LVC_LVCH245A enter image description here
PCB screen side enter image description here
Ephemeral
  • 2,157
  • the SPI could be used only for the SD card .... what does the user manual say? – jsotola May 13 '19 at 22:00
  • @jsotola, Thank you for your answers. Sorry for the "anymore" word , I'm not really English and I meant: "did not help me more than that". For SPI I have read SPI can be use for preserve GPIO pin . For SPI I read that SPI can be used to preserve GPIO pins. But I start so I can also misinterpret. In the user manual I have not found any specification about SPI, except in the diagram. – Ephemeral May 14 '19 at 07:30
  • @jsotola, Finally, the features of SPI are in manual mode: serial interface 3 lines / 4 lines, but only for SD cards? good question. – Ephemeral May 14 '19 at 07:35
  • Many thanks for the very detailed signal routing chart. I am glad to have found one more missing jigsaw piece - the relation between the signals "DC" and "SCL". I never have guessed that these two logical signals share the same physical line! – tlfong01 May 16 '19 at 04:57
  • @tlfong01, You're welcome, for my part I can not understand why there is D/CX (SCL) but also WRX (D / CX), I suspect what is noted parenthetically to be the definitions for the serial line but for the moment I'm not sure. For SDO and SDA, I can not find the relationship on the pinout of my LCD. NC / SPI_SDA ... where is this pin on my LCD screen :) If I follow your CON1 and your last schema (Update 2019may15hkt1519) this seems to be SD_DO for SPI_SDO and SD_DI for SPI_SDA but I'm not sure for the moment. – Ephemeral May 16 '19 at 07:41
    There are two separate controlling methods: using 8 pins, Using SPI. If use SPI, only use wires in CON1. You module is an Arduino shield and every pin fits OK when you insert the shield. My module has the same situation. It is for STM32, so I need to double check my guesses are correct. For the 8 pin interface, you might like to take a look of a 4 pin interface for reference - Appendix D of the following https://raspberrypi.stackexchange.com/questions/98611/raspberry-pi-with-4x20-lcd-and-pi4j-display-somethingAnyway, I am going to gym again. See you late evening or tomorrow. – tlfong01 May 16 '19 at 07:49
  • @jsotola, Thank you, I'm going to read this. Have a nice gym :) – Ephemeral May 16 '19 at 08:02
  • @jsotola, I have two units named U2 and U3, looking for U1 .. I tried to take off the screen to see if it was not below. Unfortunately I was too brutal and I broke the screen in two, that serve me as a lesson, I'm stupid. I did not find U1 and I do not see correctly where these famous pins SPI_SDA and SPI_SDO are physically connected at the level of the circuit . From your old answer you say 'NC' mean 'No Connection' , does this mean that there is no associated output pin? So is it probably possible to directly solder wires for SPI_SDA and SPI_SDO in this case. Waiting to buy the same screen . – Ephemeral May 16 '19 at 12:25
  • Sorry to hear the bad news. But don't buy the same touch screen again, because it is an Arduino shield and you are not using Arduino, are you? – tlfong01 May 16 '19 at 13:00
  • @jsotola, yes you are right , but I also use Arduino. I just have to make a choice. – Ephemeral May 16 '19 at 13:09
  • @Ephemeral Ah, so you are using Arduino and Rpi at the same time. Then there is no problem buying an touch screen Arduino shield. Earlier I checked the Arduino 2560 pinout and found that the pins don't seem to match exactly with the LCD shield. But I have not touched Arduino Uno or 2560 for a couple of years. So I guess my Arduino knowledge is a bit out of date. – tlfong01 May 18 '19 at 13:39
  • @tlfong01, Yes, sometimes I learn on arduino, sometimes on rpi. For LCD pins, this is not really a problem, because you can find in the library code the pin numbers in the source file (maybe not for all screens?). I used my screen with Arduino to do it like that and everything worked fine. But I just followed the pin numbers with a code that did not really help me understand SPI. – Ephemeral May 21 '19 at 11:02
ILI9341 SPI 2.8" Touch TFT LCD Arduino Shield
Rpi3B+ OK? How to connect?
Short Answer
(S1)
Yes, it is OK to use the ILI9341 Arduino Shield for Rpi. The following is the wiring for using SPI mode interface.
ILI9341 Touch LCD Arduino/STM32 Shield to Rpi3B+ GPIO Wiring V0.1
ici9341 wiring
The following GitHub driver by juj has a comprehensive tutorial with detail description on the following:
  1. Introduction to the touch LCD driver.
  2. How to build the kernel module.
ILI9341 Touch LCD SPI Based Driver for Rpi3B+ stretch - juj 2019apr19
Some research notes and more references can be found in the long answer below.
Long Answer
Contents
Research Notes ...
Figures ...
References ...
Appendices ...
Research Notes
(L1)
First thing first - check out spec and schematic.
touch screen 01
touch screen 2
The OP's question is clear, and his reference web links are very good. So I followed his links and jot down a picture of the wiring.
touch screen wiring
The drive/library referred by the OP is a couple of years old, and no longer supported. So I need to google to catch up.
(L2)
so I googled and found everybody is using the ILI19341 de facto standard. That means all ILI19341 are more or less the same and can be used with any such driver. I searched AliExpress and found the following typical goody.
ILI19341 touch screen
I google to catch up and the the found the following tutorial looking good.
ILI9341 Raspberry Pi guide - pi0cket 2019feb26
It gives a clear wiring (see Reference below), and the detailed instructions and commands to switch between HDMI mon and TFT screen.
One thing I am not that happy is the following:
You cannot use HDMI monitor and TFT touch screen at the same time!
Figures
Fig 1 Fig 1 - Touch LCD
Fig 2 Fig 2 - 2.8" touch screen pinout
Fig 3 Fig 3 - STM32 LCD Module 32 pin socket
Fig 4 Fig 4 - Rpi spi pinout
Fig 5 Fig 5 - Touch lcd wiring
Fig 6 Fig 6 - Touch screen module
Fig 7 - Con 1 - 9 pin x 2 = 18 pin Connector
Con 1 - 9 pin x 2 = 18 pin connector
Fig 8 - vm412 Touch LCD signals
velleman lcd 01
Fig 9 - stm32 Touch LCD signals
stm32 signals
Fig 10 Arduino Mega 2650 Pinout
arduino mega 2650 shield
Now I have my US$300, 4 channel, 50MHz, 1GSa/s Digital Storage Oscilloscope Rigol Ds1504Z ready to check out the SPI waveforms.
Fig 11 - SPI waveform
spi waveform
Fig 12 - SPI Signal Routing Cable
spi signal cable
(L3)
Now I am testing Back Lit. I found that my guess was wrong. The pin BL is not LED anode, but Low level on. I used a multimeter to check that the current from BL pin to ground is 2.5mA. So I now guess BL is not a signal pin but a pull down LED power pin, sinking 2.5 mA to switch on Back Lit LED. Anyway, I am glad that now I have a huge size 2.8" white LED! :)
bak lit test
Now I have loaded the kernel module fbtft_device name = ici9341. I can also listed the module. But I found that I made another wrong guess - four SPI signal wires are not enough, I also need 3 more GPIO wires RST, DC (select Data or Command mode), and BL (back lit), ... :(
fbtft_module_loading
My ICI9341 SPI cable V2.0 does not work, because the signals Touch LCD RST and RS (Register Select) or DC (Data Command Mode Select) are missing. So I have assembled V3.0.
ici9341 cable
I will be using GPIO Gen 0 (BCM17), 1 (BCM27) , 2(BCM22) for the ICI9341, so the modprobe command is:
modprobe fbtft_device name=ici9341 gpios=reset:17,dc:27,led:22
(L4)
Update 2019may19hkt1520
I just found that my Rpi3B+ with Raspbian 2019Apr version already has a fbtft kernel driver which sadly is not the ici I ma using. So I need to build a driver myself. I found the following driver tutorial but found it very tedious. Trying it this Sunday afternoon might corrupt my Rpi OS. So I decided to stall this part of project for a couple of days, to allow me to go through slowly the tutorial.
A blazing fast display driver for SPI-based LCD displays for Raspberry Pi A, B, 2, 3 and Zero
I am still studying the juj driver document on how to build the kernel module. I have no experience of building any linux kernel module. So I am going very slowly. I have also diverted to a test on controlling a LCD 20 char x 4 line module using 4 bit interface. This is a warm up and memory refreshing exercise in case I need to switch from SPI mode to 8bit mode for faster response.
lcd2004 test 1
LCD2004 2
/ to continue, ...
Velleman SPI 2.8" TFT LCD ILI9341 Spec - Velleman
Velleman SPI 2.8" TFT LCD ILI9341 Schematic - Velleman
Wiring up a ILI9341 TFT Touch Screen - Rpi Forum Discussion 2015
Wiring up a ILI9341 TFT Touch Screen Post - Lallafa 2013
MI0283QT-9A 320x240px Touch Screen with ILI9341 display driver spec - Mikroe
MI0283QT-9A 320x240px Touch Screen with ILI9341 display driver User Manual - Mikroe
Linux Framebuffer drivers for small TFT LCD display modules (development ceased) - 2015
AliExpress 240 x 320 2.8" SPI TFT LCD Touch Screen (Touch Pen) ILI9341 White SPI Series - US$10
AliExpress ILI9341 240 x 320 2.8" SPI TFT LCD Touch Screen
2.8 " SPI, 36.72mm W X 48.96 mm H, 8.5 x 4.8 cm/ Conductive element: active matrix a-si TFT IC Driver: ILI9341, Backlight: White LED
Visualization direction: 6 hours, Depth of color: 262 K / 65 K
Resolution): 240 RGB * 320 5V, use with 3.3 V or 5 V logic
Moduole Power = 3V3
Wiring (BCM Mode)
SCK - Rpi SPI Clok (GPIO 11)
MISO - Rpi SPI MISO (GPIO 9)
MOSI - Rpi SPI MOSI (GPIO 10)
CS - Rpi SPI CE0N (GPIO 8)
RST - Rpi GPIO GEN 6 (GPIO 25)
BL - Rpi GPIO GEN 1 (GPIO 18)
DC - Rpi GPIO GEN 5 (GPIO 24)
Touch Screen VMA412 User Manual
Ilitek ILI9341 a-Si TFT LCD Driver 240 RGB x 320 262K Color V1.02
AdaFruit 2.8" TFT LCD with Touchscreen Breakout Board User Guide
AdaFruit 2.8" TFT LCD with Touchscreen Breakout Board Pin Out / SPI Mode
AdaFruit 2.8" TFT LCD with Touchscreen Breakout Board w/MicroSD Socket - ILI9341 US$30
A blazing fast display driver for SPI-based LCD displays for Raspberry Pi A, B, 2, 3 and Zero - Last commit 2019Apr
User Manual For 2.8" TFT Touch Shield for Arduino with Resistive Touch Screen (TF028)
Wave Share 3.2 inch 320x240 Touch LCD User Manua
SPI - Serial Peripheral Interface Pinout
SPI - raspberrypi.org
Using SPI0 and SPI1
WaveShare 5" Touch LCD Setup Question and tlfong01's Answer
WaveShare 7" Touch LCD Setup Question and tlfong01's Answer
Hitachi HD44780U Dot Matrix LCD Controller Datasheet Rev. 0.0
HD44780U 4x20 LCD Controller 4-bit Interface Python Program Example
AdaFruit PiTFT Plus Assembled 320x240 2.8" TFT + Resistive Touchscreen $35 https://www.adafruit.com/product/2298
[SPI Loopback test] How to check if SPI is enabled and functional on Raspi 3b+?
Arduino Meaga 2560 Pinout
Why is SPI not working on any of my Raspis?
Display and controller Experiments - WeatherStation+
ILI9341 -Single-chip SOC driver for a-TFT liquid crystal display with resolution of 240RGBx320 dots.
ILI9341 supports parallel and serial peripheral interface (SPI). The moving picture area can be specified in internal GRAM by window address function. The specified window area can be updated selectively, so that moving picture can be displayed simultaneously independent of still picture area.
Using the AdaFruit 2.8 inch TFT display
fbtft_device GitHub - Will Price Sep 18, 2017
fbtft_device has device information for all the displays it supports, with default values. These values can be changed with module parameters.
Usage
There is one required module parameter, and that is name. It specifies which display (device) to register.
eg, sudo modprobe fbtft_device name=adafruit22
fbtft_device prints information to the kernel log
$ dmesg
fbtft_device: SPI devices registered: fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00 fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
fbtft_device: 'fb' Platform devices registered: fbtft_device:
bcm2708_fb id=-1 pdata? no
fbtft_device: Deleting spi0.0
fbtft_device: GPIOS used by 'adafruit22': fbtft_device: 'reset' = GPIO25 fbtft_device: 'led' = GPIO23
fbtft_device: SPI devices registered: fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00 fbtft_device: fb_hx8340bn spi0.0 32000kHz 8 bits mode=0x00
graphics fb1: fb_hx8340bn frame buffer, 176x220, 75 KiB video memory, 16 KiB buffer memory, fps=20, spi0.0 at 32 MHz
First it lists all SPI devices and platform devices with a name containing 'fb' (framebuffer) that was registered before the module was loaded.
Then it deletes the device connected to spi0.0 (spidev) so we can register a new one.
Then it tells which GPIOs that is associated with this display.
Then it lists which SPI devices that are currently registered (spi0.0 means SPI busnum.chipselect).
And lastly the driver is loaded.
Supported devices
The special name list will write the supported devices to the kernel log.
sudo modprobe fbtft_device name=list; dmesg | tail -30
ERROR: could not insert 'fbtft_device': Operation canceled
fbtft_device: SPI devices registered: fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00 fbtft_device: 'fb' Platform devices registered: fbtft_device: bcm2708_fb id=-1 pdata? no fbtft_device: Supported displays: fbtft_device: adafruit18 fbtft_device: adafruit18_green fbtft_device: adafruit22 ...
Parameters
busnum SPI bus number (default=0)
cs SPI chip select (default=0)
speed SPI speed in Hz (default varies among displays)
mode SPI mode (default SPI_MODE_0)
rotate Angle to rotate display counter clockwise: 0, 90, 180, 270
bgr Set BGR bit (supported by some drivers). Use if Red and Blue is swapped. Default is don't touch.
> gpios Most displays need GPIOs for signaling. To simplify configuration, pins with the same functionality has been given names:
reset - Hardware reset
dc - Data/Command (sometimes called RS) [no wonder I got confused - tlfong01]
led - Backlight
> GPIO only displays [not used for SPI mode tlfong01 2019may18]
db00-15 - Databus
cs - Chip Select
wr - Write strobe
fbtft_device have default values for these pin names (a few don't). The values can be changed with the gpios parameter. This is a comma separated array of pin/signal names and GPIO numbers. gpios=pin_name:gpio_number[,pin_name:gpio_number]
When overriding the defaults using gpios, all gpios must be specified.
Example showing the default gpio values of itdb28fb
> modprobe fbtft_device name=itdb28 gpios=reset:17,dc:1,wr:0,cs:21,db00:9,db01:11
Explaining Linux kernel modules, devices, and drivers
How to setup an LCD Touch Screen on Rpi - Waveshare
Raspberry PI OLED Library Driver
Appendices
Appendix A - ILI9341 Touch Screen Wiring V0.1 tlfong01 2019oct19hkt2217
ili9341 wiring
  • Thank you very much, I have already seen (hover over) all the tutorials provided but I do not understand how to connect "BL" (from ILI9341 Raspberry Pi guide - pi0cket) for example, I can not see it on the diagram (that you kindly highlighted me). Another remark is for pin SPI_SDO, SPI_SDA there is NC / SPI_, the NC scares me ... – Ephemeral May 14 '19 at 07:47
  • Ah, no problem. Perhaps I can draw a diagram to explain it better. – tlfong01 May 14 '19 at 07:50
  • It would be with great pleasure but I would not want to take up too much of your time. – Ephemeral May 14 '19 at 07:51
    Ah I see your problem. They are using hard to understand geek language. "NC" usually means "No Connection". “BL” usually means "Back Lit". The module has 4 white LED which can back light the background. No problem for me drawing anything. It take me very littl time. – tlfong01 May 14 '19 at 08:20
  • Thank you very much again for all your explanations. I think at this time, GPIO9 -> LCD_RD , GPIO10 -> LCD_WR, GPIO8 -> LCD_CS but for RESET and RS (Register Select ?) no definition on pinout shematic for the raspberry. Maybe these pins can be any pin gpio (declared in the driver source file?) raspberry pinout – Ephemeral May 14 '19 at 08:27
  • Yes, it is confusing. I am trying to make some educational guesses, as in the coming updated picture. BTW, my answer is not just for you, but a follow up of other touch screens answers for newbies. For me it is just like a jigsaw puzzle, which is my hobby of playing electronics toys. Now I am going to meet a friend for supper. So see you tomorrow. Have a nice project! – tlfong01 May 14 '19 at 08:59
  • I can not thank you enough. Have a good dinner. I will work with the elements of your updated answer. – Ephemeral May 14 '19 at 09:07
  • @Ephemeral I googled more touch LCD user guides and found all of them similar. So I have drafted a basic wiring diagram as updated. I think you can find the SPI signal lines at the Arduino shield plug CON 1, and one more CS signal line for micro SD card at the bottom side of the PCB. (Main SPI line are shared between LCD and sd card。) I could not find any BL line in your board. Perhaps your board has no back lit. Or you can try searching for it. I am going to gym then supper. See you late evening or tomorrow. Good luck! – tlfong01 May 15 '19 at 07:29
  • Again, thank you very much. For 'BL', I can see LEDA on pin 16 and LEDK on pin 17 (LEDA seems to be the only pin needed on the diagram), but I really do not understand the pin mapping for the final board. And then what would LEDK be used for ? ... Have a good supper. – Ephemeral May 15 '19 at 09:01
  • For SPI it means that I can not make a display request and a request to access the SD card at the same time ? Can we say that this works in half-duplex ? – Ephemeral May 15 '19 at 09:22
  • Ah. LEDA means LED Anode, which means Positive. LEDK means LED Cathode, Negative side. So if you connect Anode (to be very safe, use 1k in series to limit current) to 3V3, and Cathode to Gnd, the back lit LED should light up. – tlfong01 May 15 '19 at 10:29
  • Ah, let us consider one device at a time. A SPI operation is almost always write and read at the same time, sort of mouth talking and ears listening at the same time. So it is full duplex, if you wish to use this term half/full duplex. Same for SD card, you write and read at the same time. Now you can read a byte from LCD and then write the byte to SD. But this has nothing to do with half or full duplex, I think, not very sure, again. You need to wiki for SPI, and also google Rpi newbit tutorials on SPI and I2C etc, to clarify. – tlfong01 May 15 '19 at 10:35
  • Thank you for all your clarifications. For the lighting the schema of the diodes watches a schema with a pin named 'A' and 4 Leds in parallel. It seemed to me that LEDA could have been used for this pin. Yes, you're right, I'm going to read the ILI9341 data sheet provided by adafruit to read a bit more about SPI and I2C. But I do not know if it will allow me to find the connection for the spi clock, the back light etc ... because everything is on the diagram of the screen finally. – Ephemeral May 15 '19 at 10:46
  • Ah, the four most important spi wires you want is located in CON1. Look for this plug in my picture updated yesterday. – tlfong01 May 15 '19 at 11:14
  • Yes I will look even more carefully. After thinking, in fact, I should not rather look at your last schema which is much clearer for me and my level because I can not find a match for the clock for example apart from in your last scheme. If I understand what you told me before then I just miss the pin for the back light. But I am beginning to doubt my ability to properly configure the outputs in the driver source since I can not easily understand a simple connection and associate the technical terms. – Ephemeral May 15 '19 at 11:23
  • Yes, I agree. If you cannot guess the meaning of terms BL = Back Lit, and LEDA, LEDK mean Anode and Cathode, then it is very difficult to do it all by yourself. But then if you read AdaFruit's newbie tutorials on touch LCD, you might find things not that difficult. Or if you search Amazon's touch LCD for Rpi, you might also find it easy. Your problem is now you want to change an Arduino shield to Rpi compatible, that is indeed very difficult. Suggestion: watch what I do this weekend, then decide to give up for now and come back later, after learning SPI basics. – tlfong01 May 15 '19 at 11:42
  • Thank you. I understand you, but I am simply confused because I have a little experience of programming with SPI. On the original vellman diagram, you have highlighted 5 'wires', on the diagram of lallafa's 4 'wires' are highlighted. When I program an ATtiny (which happened to me once or twice) with SPI I use 4 'wires'. I do not try to make all the features of the screen, touchscreen, access to the SD card etc but rather to do a simple SPI link is to write text to start,I have this screen on hand so I thought maybe it's possible to just connect to the raspberry. – Ephemeral May 15 '19 at 11:57
  • Ah, you only need 4 wires for the LCD - CLK, MOSI, MISO, CS. The 5th wire is CS for the SD card. So actually we don't need to bother the SD card, or even the back lit, just play with LCD to start with. As I said, you can just sit back, do nothing and watch how do I test the very basic SPI thing over the weekend, ... – tlfong01 May 15 '19 at 12:45
  • @Ephemeral Now I have added Fig 8, 9 for vm412 and stm32 signals. Next is to test BL and then SPI. – tlfong01 May 17 '19 at 01:43
  • yes I see that . I follow your updates. This is a complete LCD tut's :) – Ephemeral May 17 '19 at 19:51
  • @Ephemeral Ah you remind me another user commenting that my very long answer to his short questions is like a blog. My reply was that I used to hesitate to give an answer which I am not very sure correct. So I usually say, pretty sure, 60% chance and so on. If it happens that the question is related to my own project, then I would do some research as in this touch LCD case. Actually I am at the same time researching on 20 char x 4 line LCD with buttons. I know 20x4 LCD very well, but only using Arduino C++, so I need to try on Rpi python to make sure, otherwise I am misleading the OP. – tlfong01 May 18 '19 at 13:48
    Some clarifications: (1) There are two types of ILI9341 Arduino shields, one for Arduino Uno or similar, another for Mega 2560. You board is for 2560, which might not fit if you are using Uno. (2) There are two SPI wiring methods, 3 wires method does not use DC signal. (3) MISO is always not used. The details can be found in the driver tutorial below: https://github.com/juj/fbcp-ili9341 – tlfong01 May 19 '19 at 07:31
  • Thank you very much again for all this information. – Ephemeral May 21 '19 at 11:14
    You are welcome. I am still studying the juj driver document on how to build the kernel module. I have no experience of building any linux kernel module. So I am going very slowly. I have also diverted to a test on controlling a LCD 20 char x 4 line module using 4 bit interface. This is a warm up and memory refreshing exercise in case I need to switch from SPI mode to 8bit mode for faster response. You might like to come back from time to time to see my progress. – tlfong01 May 21 '19 at 13:03
I do not know if you fixed issues already but you cannot connect your 8bit paralel tft display via SPI. SPI interface uses less wires for connection as 8-bit parallel which is yours case. At first check what display do you have. you can see it on notro wiki: https://github.com/notro/fbtft/wiki/LCD-Modules . From pictures you posted you have 8-bit parallel interface (dc, wr, reset, cs, db00-07). You can follow also this page: https://github.com/nopnop2002/Raspberry-ili9325/wiki/FrameBuffer-Setting-to-ILI9341, where you have also gpio numbers for connection to display
tuto ruto
