I am trying to install HY463 touch screen driver on to raspberrypi-cm3 buster lite. I have installed drivers before. But Their website does not provide any Makefile or any documentation for me to compile/add the drivers
Can anyone provide me any pointers or documentation that could help me
Edit1: Adding the link to website: https://www.hycontek.com/en/category/products-en/touch-en
Edit2: I now see a pdf document which look like it has instructions on how to add it. So I am translating that now
Edit3: So according to the document I have to do these below steps
4.1 Migration File This section describes how to transplant our driver. The functions implemented include driver mount, touch point report, sleep wake-up FW upgrade and other interfaces for APK and ADB debug call.
1. Copy the hy46xx_ts.c and hy46xx_ts.h files to the kernel/include/linux/input/touchscreen/ directory.
2. Modify the Makefile in the kernel/include/linux/input/touchscreen/ directory and add a line to the end of this file: obj-$(CONFIG_TOUCHSCREEN_HYCON) += hy46xx_ts.o
4.2 Compile After completing the work described in Section 4.1 You can compile the kernel, enter the compile command at the command line: Make -j4 bootimage Wait for the compilation to complete, compile successfully will generate boot.img.
But This document still does not tell me how to compile it after boot-up. I cannot do this above method because. My Image now has cross-compile tool and all packages installed on it. If I now create a new image then I would have to do that all over again
Can someone give me any pointers on how to generate a Makefile and then add this touchscreen module
Their websiteis practically useless ... please add a link to the website – jsotola Sep 12 '19 at 00:06
