I've been using the Adafruit PiOLED which causes some issues with the PiSugar 2 battery I'm using. Because of this, I'm looking for recommendations on a screen that doesn't use the I2C protocol. I'd prefer one with no touch screen if possible.
Asked
Active
Viewed 127 times
Ah, there are in general two kinds of communication protocols for LCD/LED screens: I2C and SPI. For Rpi, there is a special interface for screens. You can google Rpi to find out more. – tlfong01 Jan 07 '21 at 14:55
Gotcha, any recommendations for an SPI screen? I'm currently looking at this one: https://www.adafruit.com/product/4393 – Justanothermatt Jan 07 '21 at 15:06
To add some context about the one I posted, I'm worried about using it because it is wired to use I2C but only for the STEMMA QT / Qwiic connector. If I omit that cable, I'm worried it will still cause issues – Justanothermatt Jan 07 '21 at 15:10
I only know that Qwiic is SparkFun thing, but it is a physical non standard, so you can do your rewiring, similar to what I mess around RS232/serial standards with my own wiring hardware (yes, no nothing about DB9, double shielding etc, just cheapy 2.54 DuPont connectors), in my toy projects (115kBd, home environment). – tlfong01 Jan 08 '21 at 02:45
I have posted a couple of answers in this forum on SPI/I2C LCD/LED displays. This is an example: https://raspberrypi.stackexchange.com/questions/98549/rpi3b-rpi4b-ili9341-xpt2046-spi-2-8-touch-tft-lcd-connection-driver-problem. I vaguely remember my last post is about Piromoni SPI display which I think is good. I usually follow tutorials from AdaFruit and WaveShare, less frequently but more recently Piromoni and sparkFun. – tlfong01 Jan 08 '21 at 02:50
BTW, I do find I2C OLED OK. In case you change your mind, you might like to check out how I mess around with little I2C OLEDs: https://raspberrypi.stackexchange.com/questions/106482/rpi3b-ssd1306-oled-i2c-interface-problem. Cheers. – tlfong01 Jan 08 '21 at 02:57
