You might like to try my little test program, under GUI Desktop IDLE
python. Or run under terminal mode with sudo.
# spi_test05 tlfong01 2019apr07hkt2043 ***
# Computer = Rpi3B+
# Linux = $ hostnamectl = raspberrypi Raspbian GNU/Linux 9 (stretch) Linux 4.14.34-v7+ arm
# Python = >>> sys.version = 3.5.3 Jan 19 2017
# Test 1 - repeatSendByte() - SPI port repeatedly send out single bytes.
# Function - Repeat many times sending a byte, pause after each byte.
# Test 2 - loopBackTest() - SPI port send and receive one byte.
# Function - Send one byte to MSOI and read it back from MISO.
# Setup - Connet MOSI pin to MISO pin to form a loop.
from time import sleep
import spidev
spiPort0 = spidev.SpiDev()
spiPort0.open(0,0)
spiPort0.max_speed_hz = 100000
def spiSendRecvOneByte(spiPort, sendByte):
sendByteArray = [sendByte]
recvByteArray = spiPort.xfer(sendByteArray)
return recvByteArray
def repeatSendOneByte(spiPort, sendByte, pauseTimeBetweenBytes, repeatCount):
print('\nBegin repeatSendByte(),....')
for i in range(repeatCount):
sleep(pauseTimeBetweenBytes)
print('End repeatSendByte().')
return
def loopBackOneByte(spiPort, sendByte):
recvByteArray = spiSendRecvOneByte(spiPort, sendByte)
recvByte = recvByteArray[0]
print('\nBegin testLoopbackOneByte(),....')
#print('')
print(' sendByte = ', hex(sendByte))
print(' recvByte = ', hex(recvByte))
#print('')
print('End testLoopbackOneByte(),....')
return
def testRepeatSendOneByte():
repeatSendOneByte(spiPort0, 0x5b, 0.0001, 20000000)
return
def testLoopbackOneByte():
loopBackOneByte(spiPort0, 0x5b)
return
#testLoopbackOneByte()
''' Smple output tlfong 01 2019apr07hkt2047
sendByte = 0x5b
recvByte = 0x5b
# *** End ***
Appendices
Appendix A - Rpi SPI pinout
sudo pigpiodthenpigs spio 0 50000 0thenpigs spix 0 0xaa 0x55and check on the scope. – joan Apr 07 '19 at 11:31
