I'm trying to read a SPI sensor via the raspberry pi, but I seem to be getting strange voltage levels on the MOSI line and no response on the MISO line. The chip-select line and clock lines make sense.
The kernel module appears loaded:
$ ls -l /dev/spi*
crw-rw-rw- 1 root spi 153, 0 Aug 8 09:17 /dev/spidev0.0
crw-rw-rw- 1 root spi 153, 1 Aug 8 09:17 /dev/spidev0.1
$ lsmod | grep spi
spidev 20480 0
spi_bcm2835 20480 0
$ modinfo spidev
filename: /lib/modules/4.19.57-v7+/kernel/drivers/spi/spidev.ko
alias: spi:spidev
license: GPL
description: User mode SPI device interface
author: Andrea Paterniani, <a.paterniani@swapp-eng.it>
srcversion: 4EE702C8B42456520F93538
alias: of:N*T*CspidevC*
alias: of:N*T*Csemtech,sx1301C*
alias: of:N*T*Cge,achcC*
alias: of:N*T*Clineartechnology,ltc2488C*
alias: of:N*T*Crohm,dh2228fvC*
depends:
intree: Y
vermagic: 4.19.57-v7+ SMP mod_unload modversions ARMv7 p2v8
parm: bufsiz:data bytes in biggest supported SPI message (uint)
I don't get any errors on initializing the module:
import spidev
class RpiSpi():
BUS_SPEED_HZ = 100000
MODE = 0
def __init__(self, bus, device):
# Enable SPI
self._spi = spidev.SpiDev()
# Open a connection to a specific device (chip-select pin)
# and bus. There are two buses available.
self._spi.open(bus, device)
# Set SPI speed and mode
self._spi.max_speed_hz = RpiSpi.BUS_SPEED_HZ
self._spi.mode = RpiSpi.MODE
def write_reg(self, reg, value):
self._spi.xfer2([reg, value])
def read_reg(self, reg):
response = self._spi.xfer2([reg, 0x00])
return response[1]
sensor = RpiSpi()
sensor.write_reg(0x70, 0b01000000)
while True:
time.sleep(1)
print(sensor.read_reg(0x75))
I've tried all permutations of mode and bus/device combos.
The MOSI line on an oscilloscope looks weird (2.5 V in some places when I would expect 3.3 V):
Hardware: Raspberry Pi 3 Model B V1.2
spidev module documentation: http://tightdev.net/SpiDev_Doc.pdf
(2) https://raspberrypi.stackexchange.com/questions/96225/why-is-spi-not-working-on-any-of-my-raspis
– tlfong01 Aug 08 '19 at 07:26
