a few days ago i connected an ili9341 diaplay (https://www.aliexpress.com/item/32961284118.html) to my raspberry pi , and after installing all the required python thinks , i runned a simple code and it just worked, but because i have a little 5V fan , that i tooked appart the connector , and i connected it to 3.3v , from mistake i shorted 3.3V and 5V line of the raspberry pi , and since then the screen is only white. What is broken now, the pi's spi interface or my display? (i have no way to test the display) and the raspberry pi is still working fine. I can also controll the gpio 22 just fine (the gpio thats connected to the displays backlight)
Asked
Active
Viewed 192 times
1please draw a diagram of the connections ... show what you shorted together .... also, it is not possible to answer "What is broken", only "What could be broken" – jsotola Feb 21 '21 at 19:03
I have a couple of posts on ILI9341 SPI TFT white screen. Here is an example you might find helpful. [1] Rpi3B/Rpi4B ILI9341 / XPT2046 SPI 2.8" Touch TFT LCD Connection / Driver Problem https://raspberrypi.stackexchange.com/questions/98549/rpi3b-rpi4b-ili9341-xpt2046-spi-2-8-touch-tft-lcd-connection-driver-problem/98557#98557. Good luck. Cheers. – tlfong01 Feb 22 '21 at 01:26
Does your RPI boot if you remove the screen? You may have destoyed the power management IC by connecting 3.3V to 5V. – Dougie Feb 22 '21 at 10:20
@Dougie the pi works just fine, the display doesnt – Baciu Florin-Geroge Feb 22 '21 at 16:02
@jsotola the connection from the display to pi are as follows: MISO-MISO SCK-SCK 3.3V-VCC GND-GND CE0-CE GPIO 24-DC 3.3v-LED – Baciu Florin-Geroge Feb 22 '21 at 16:03
