(A) How to use Rpi Pico W to repair a broken ILI9341 LCD display module? - Selecting the module for testing.
(B) Rpi Pico W SPI Wiring Notes
I am thinking of using PicoW's SPI #1 to connect to the ILI9341 LCD display module (GPIO 21~27).
(C) ILI9341 SPI Wiring for troubleshooting
(D) PicoW SPI0 signal timing
PicoW ili9341_SPI testing_2023mar26hkt1516 v01 program listing
(E) PicoW SPI reading ILI9341 registers
(F) PicoW ILI9341 Wiring Diagram
(a) Connect an SPI LCD Display to Your Raspberry Pi Pico Using MicroPython ILI9341 Driver - Bob, bytesNbits 2021dec29
(b) ILI9341 TFT LCD Single Chip Driver 240 RGB x 320 datasheet v1.11 - ilitek
(G) RPi Pico/MicroPython + ILI9341 SPI Display with Touch - Rdagger
(a) RPi Pico/MicroPython + ILI9341 SPI Display with Touch, using rdagger/micropython-ili9341 - Hello Rpi, 2021mar06
(b) rdagger/micropython-ili9341 (MicroPython ILI9341Display & XPT2046 Touch Screen Driver) - 2022sep03
(H) ILI9341 LCD Touch Screen Setup and Troubleshooting
(a) RPi Pico/MicroPython + ILI9341 SPI Display with Touch, using rdagger/micropython-ili9341 - HelloRpi 2021mar06
(b) ILI9341 2.4inch SPI Module ILI9341 SKU:MSP2402 - LcdWiki
(c) ILI9341 2.4inch SPI Module ILI9341 SKU:MSP2402 User Manual - LcdWiki
Touch screen signal line wiring
10 T_CLK Touch SPI bus clock signal
11 T_CS Touch screen chip select signal, low level enable
12 T_DIN Touch SPI bus input
13 T_DO Touch SPI bus output
14 T_IRQ Touch screen interrupt signal, low level when touch is detected
(I) So I repeated the OP's white screen
PicoW ILI9341 Wiring Scheme v0.1
(J) ILI9341 White Screen Troubleshooting Suggestion
(a) framebuf - microphon.org
(b) newdigate / rgb565_colors colour name definitions - github
(c) Color Depth (65k, 262k, 16.7M Colors) - focusLeds
(d) Multi Thread Coding on the Raspberry Pi Pico in MicroPython - Threads, Locks and problems!
(e) getis/pi-pico-spi-lcd-ili9341-st7789 Public
framebuf — frame buffer manipulation - micropython.org
This module provides a general frame buffer which can be used to create bitmap images, which can then be sent to a display.
class FrameBuffer
The FrameBuffer class provides a pixel buffer which can be drawn upon with pixels, lines, rectangles, ellipses, polygons, text and even other FrameBuffers. It is useful when generating output for displays.
For example:
import framebuf
FrameBuffer needs 2 bytes for every RGB565 pixel
fbuf = framebuf.FrameBuffer(bytearray(100 * 10 * 2), 100, 10, framebuf.RGB565)
fbuf.fill(0)
fbuf.text('MicroPython!', 0, 0, 0xffff)
fbuf.hline(0, 9, 96, 0xffff)
(K) XPT2046 Touch Screen Controller
XPT2046 Touch Screen Controller Datasheet - XPTek 2007may
rdagger/micropython-ili9341 /xpt2046.py (Serial interface for XPT2046 Touch Screen Controller) - Rdagger
rdagger xpt2046.py program listing
i dont think i broke anything
- your description suggests otherwise – Jaromanda X Mar 20 '23 at 22:35(b) ILI9341 3.2 inch SPI Module ILI9341 SKU:MSP3218 Reference - : LcdWiki http://www.lcdwiki.com/3.2inch_SPI_Module_ILI9341_SKU:MSP3218
– tlfong01 Mar 22 '23 at 03:47
