While searching I came across some of Joan's code (which has been recently published or updated) - this seemed to fit the bill (even though it looked too simple).
There is none of the arcane installation Adafruit required and it seems to work every time without missing readings due to timing errors.
All that is needed is a simple python module and pigpiod - which is included in Raspbian.
I wrote the following wrapper around this module:-
#!/usr/bin/env python3
# Program to read current temperature and humidity and post single message to MQTT BROKER
A Program to read the DHTXX temperature/humidity sensors.
Post single message to MQTT BROKER
REQUIREMENTS
DHT.py download "module" from http://abyz.me.uk/rpi/pigpio/code/DHT.py
pigpiod running
apt-get install -y mosquitto mosquitto-clients
sudo pip3 install paho-mqtt
import paho.mqtt.publish as publish
import json
BROKER = 'localhost'
sensor_data = {'date': 0, 'temperature': 0, 'humidity': 0}
topicPrefix = "weather"
import sys
import pigpio
import DHT
import time
import datetime
# Sensor should be set to DHT.DHT11, DHT.DHTXX or DHT.DHTAUTO
sensor = DHT.DHT11
pin = 4 # Data - Pin 7 (BCM 4)
def output_data(timestamp, temperature, humidity):
# Sample output Date: 2019-11-17T10:55:08, Temperature: 25°C, Humidity: 72%
date = datetime.datetime.fromtimestamp(timestamp).replace(microsecond=0).isoformat()
# print(u"Date: {:s}, Temperature: {:g}\u00b0C, Humidity: {:g}%".format(date, temperature, humidity))
sensor_data['temperature'] = temperature
sensor_data['humidity'] = humidity
sensor_data['date'] = date
publish.single(topicPrefix, payload=json.dumps(sensor_data), qos=1, retain=True, hostname=BROKER,
port=1883, client_id="RaspberryPi", keepalive=60)
pi = pigpio.pi()
if not pi.connected:
exit()
s = DHT.sensor(pi, pin, model = sensor)
tries = 5 # try 5 times if error
while tries:
try:
timestamp, gpio, status, temperature, humidity = s.read() #read DHT device
if(status == DHT.DHT_TIMEOUT): # no response from sensor
exit()
if(status == DHT.DHT_GOOD):
exit() # Exit after successful read
time.sleep(2)
tries -=1
except KeyboardInterrupt:
break
This code is intended to run from crontab
NOTE Unless DHT.py is in the same directory it should be in a directory on the PYTHONPATH
The following is an extract from my crontab.
PYTHONPATH=/home/pi/bin/python
# This will publish into Broker on localhost
# Should Publish nothing if sensor missing
1,16,31,46 * * * * /home/pi/mqtt-dht11s.py
