I connected a DHT-11 to the GPIO04 pin and wrote this code down.
import Adafruit_DHT
sensor = Adafruit_DHT.DHT22 pin = 7
while True: humidity, temperature = Adafruit_DHT.read_retry(sensor, pin) print(temperature, humidity)
It just prints None None and does nothing else. Thanks for all the help!~
Edit: I ran this code
import sys
import pigpio
import DHT
import time
import datetime
Sensor should be set to DHT.DHT11, DHT.DHTXX or DHT.DHTAUTO
sensor = DHT.DHT11
pin = 4 # Data - Pin 7 (BCM 4)
def output_data(timestamp, temperature, humidity): # Sample output Date: 2019-11-17T10:55:08, Temperature: 25°C, Humidity: 72% date = datetime.datetime.fromtimestamp(timestamp).replace(microsecond=0).isoformat() print(u"Date: {:s}, Temperature: {:g}\u00b0C, Humidity: {:g}%".format(date, temperature, humidity))
pi = pigpio.pi() if not pi.connected: exit()
s = DHT.sensor(pi, pin, model = sensor)
tries = 5 # try 5 times if error while tries: try: timestamp, gpio, status, temperature, humidity = s.read() #read DHT device if(status == DHT.DHT_TIMEOUT): # no response from sensor exit() if(status == DHT.DHT_GOOD): output_data(timestamp, temperature, humidity) exit() # Exit after successful read time.sleep(2) tries -=1 except KeyboardInterrupt: break
and it came out as process ended as with exit code 0
yesn't
0 Answers0
