I have RPI Zero with DHT11 connected as recommended (diagram) and I was reading data from it with ~90 % success rate every 5 minutes using the old Adafruit library. But today morning it stopped receiving data so I tried to troubleshoot it using new Adafruit library and it seems like there is connection issue:
DHT sensor not found, check wiring
Notes:
- I am using 10K resistor.
- DHT11 is connected to GPIO4 (pin 7)
- I was able to measure voltage changes on the sensor, so I believe the wiring is OK
When running joans DHT.py, I was able to read the values for the first time, but then error appered:
pi@raspberrypi:~/Teplomer $ ./DHT.py 4
1583582364.035 4 0 24.0 57.0
1583582366.112 4 2 24.0 57.0
^Ccancelling 4
1583582386.131 4 2 0.0 0.0
1583582388.205 4 2 0.0 0.0
1583582390.279 4 2 0.0 0.0
^Ccancelling 4
1583582738.135 4 3 0.0 0.0
1583582740.407 4 0 23.0 53.0
1583582742.480 4 2 23.0 53.0
^Ccancelling 4
1583582746.751 4 0 23.0 53.0
1583582748.825 4 2 23.0 53.0
1583582750.899 4 2 23.0 53.0
^Ccancelling 4
1583582779.302 4 2 0.0 0.0
1583582781.376 4 0 23.0 53.0
However, I did not move any parts so it seems like the sensor is dead?
How can I troubleshoot it?
Thank you!
