Project Overview
I have a series of RPi 3B+ which collect T/RH data using connected sensors. These "periphery" units collect data every 5 minutes, append the data to a CSV file that holds a day's worth of data, and stores the data locally in a /data/ directory.
I have a "master" RPi 3B+ whose job is to periodically (approximately every 15 minutes) connect to these periphery units via SSH and copy the available data from the /data/ directory, process it, generate figures, and push these figures to GitHub.
The master RPi has been set up to connect without a password to the periphery units via ssh-copy-id. I was able to ssh into the periphery units from the master and, through that, stored the periphery units in the /home/pi/.ssh/known_hosts directory.
The Problem
I created a script to automate this process and it works perfectly when I manually run it. The code used to connect to each device and download the data is shown below:
os.system(f'scp -r -o ConnectTimeout=3 pi@{ip_address}:{path_to_raw} {self.path_to_data}/interim/')
I have run the script successfully both within and outside a virtual environment. The problem happens when I try to schedule the script via /etc/crontab. When I do this, the master can no longer connect to the periphery units with the error Host key verification failed. The /etc/crontab file is below:
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
Example of job definition:
.---------------- minute (0 - 59)
| .------------- hour (0 - 23)
| | .---------- day of month (1 - 31)
| | | .------- month (1 - 12) OR jan,feb,mar,apr ...
| | | | .---- day of week (0 - 6) (Sunday=0 or 7) OR sun,mon,tue,wed,thu,fri,sat
* * * * * user-name command to be executed
#/5 * * * root sh /home/pi/bleed-orange-measure-iaq/update_figures.sh
/5 * * * root /usr/bin/python3 /home/pi/bleed-orange-measure-iaq/src/data/make_dashboard.py
The first command I have commented out was my attempt to run the script by wrapping it in a shell script but that was also unsuccessful so I figured I would just execute the python command.
The Question
My question is why can I not connect to the periphery units when I place the script within crontab or in a service file? I understand now that the cron and login environments are different, but I have supplied both a PATH environment variable and used full path names.
sshlooks for the host key. The host key is stored in theknown_hostsfile. Theknown_hostsfile is stored in/home/pi (or your username)/.ssh/folder when you usesshas the normal user. In the cronttab you use the script asroot. In that casesshlooks forknown_hostsin the folder/root/.ssh/. It does not find that file or the particular entry in the fileknown_hostsforroot, as the host is "unknown" to theroot. – user68186 May 22 '22 at 17:46crontabwithsudo crontab -e. This created a crontab for theroot. You can revert the change and usecrontab -eas the normal userpiorfritzor whatever, and put the line there, then thescpwill run as the user, and not root. – user68186 May 22 '22 at 17:56piworked. Thank you for pointing out that there are multiple locations for theknown_hostsfile. – Fruity Fritz May 27 '22 at 16:15
