Does anyone have any ideas on how I can use RPI with ADC to measure a tank level sensor which has a range of only 20 to 200 ohm.
Does anyone have any ideas on how I can use RPI with ADC to measure a tank level sensor which has a range of only 20 to 200 ohm?
Short Answer
Some months ago I played with a couple of moisture sensor / level detectors. Below is an example.
Water Level Detection Discussion - Rpi StackExchnge
However the above sensor does not answer the OP's question, which asks to detect resistance using ADC, not analog or digital voltage levels. So I think I need to start from a variable resistance and check out how to use ADC to measure the resistance, within a range of 20 to 200 ohms.
I very surprisingly found that all the five samples from different manufacturers have the same resistance of 0.5 ohms for each of the two resistive "legs".
Anyway, I think I can try to use an ADC that can measure my sensor's 0.5 ohm range, and also the OP's 20~200 ohm range. I am thinking of starting with the cheapest, and lowest resolution ADC/DAC PCF8591. If its low resolution is not enough for 0.5 ohm range, then perhaps I will try others, such as MCP3x02/04/08. The good thing about PCF8591 is that there is cheapy module available, and programming easy, so is newbie friendly. On the other hand, MCP3x02/04/08 is big family of ADCs, from 12 bits to 18 bits (MCP3404)
Long Answer
/ long answer to prune later, ...
Introduction and Summary
Question Analysis
I think the preliminary functional spec of the project is very good, because it is concise and precise.
There are many reasons that the question is so short, but I will not list my wild guesses for now. Perhaps later.
The spec includes the following key words/phrases:
"Rpi, ADC, tank level sensor, 20Ω ~ 200Ω.
The word "tank", is crucial. She says "tank", not "container", perhaps she wants to indicate that the "tank" is deep , say, not a 5 inches deep fish "bowl" or "pond".
The phrase "20Ω ~ 200Ω" is also crucial. There are basically two types of liquid level sensors: active and inactive. Active sensors are usually 5V or 12V powered, and the sensor output is a DC voltage level. Inactive sensors don't have any power. Usually the sensor is just a reed switch and floating magnet, or a long "resistor" whose resistance varies as the water level. Usually the resistor is far, perhaps 10ft, and up to 1,000 ft from the measuring instrument.
(1) Water Level Detection Discussion - Rpi StackExchnge
(3) AliEXpress Non-contact Level Sensors
(4) AliExpress10A/250V Water Level Controller Module
(5) AliExpress Water level sensor Water drops tester
(6) AliExpress 5~24V 5mA Non-contact Induction Water Level Sensor
(7) Gig (ee, rpi, arduino) projects
(8) ph Sensor using sensor and ADCs PCF8591 and MCP3208
(9) How to use Rpi [python] to read [SPI MCP3008] ADC of a [water] tank level sensor? [Too many down votes make ext and imaged blurred]
(10) MCP3008 outputting just zero
(11) Rpi reading only zero output results from SPI 10-bit ADC MCP3008 problem
(12) How to increase sampling rate [higher resolution using MCP3208] on MCP3008 in python
(13) Interpreting voltage output on ADC with rated AC current sensor [MCP3008/MCP3208
(14) MCP3008 with photoresistor [nonlinear LDR], analog to digital, noisy readings
(15) How to use Rpi python to control PCM1802 24-bit HiFi stereo ADC and MAX4466 microphone amplifier
End of Answer
- 4,665
- 3
- 10
- 24
yes... do you really want to ask a question that has a yes/no answer? – jsotola Jun 13 '19 at 15:43
