I wrote a script using GPIO pins and I'm fairly certain there was no
way for it to cause a short circuit.
Answer
Well, if you are connecting a GPIO pin to any pin of a 5V powered
device, then there is risk of frying the Rpi or shortening it life。
You might like to read the following posts for more details.
DHT11 sensor and the wrong voltage may have fried my RPi3 [Rpi Latching Up Instant Suicide]
Circuit wiring issue [Rpi Latching up Slow Suicide]
Reading Output signal from external circuit using Rpi GPIO Pin
Rpi Latch Up Discussion Notes 1
Rpi Latch Up Discussion Notes 2
Rpi 5V Low Trigger Relay Latching Up Risk Notes
Appendices
Appendix A - Warning on dangerous pulling up GPIO pin to 5V
GPIO Electrical Specifications Raspberry Pi input and output pin voltage and current capability - Mosiac Documentation Web
GPIO pin circuitry
The internal diodes shown in the figure are not really substrate
diodes, but they are actually parasitic FETs.
Electrically, their I-V characteristic looks like a diode's, but with
a greater forward drop and a more gradual knee.
They may protect against low current transient events caused by
transient out-of-range voltages applied to the pins, but they are not
intended to protect against the application of voltages greater than
the supply voltage or less than ground, even with an external series
resistor.
In brief, you should never deliberately forward bias those "diodes".
Consequently, you can not safely place an external pull-up resistor to
5V on the I/O pin. That would forward bias a parasitic FET and owing
to its poor internal impedance to the chip's internal power rail it
may overheat, or worse, it may bias up parts of the chip to voltages
greater than they can handle.
So, don't do it!
