I am trying to use the DHT11 sensor temprature and humidity sensor with my Raspberry Pi 4B. When I connect the sensor with my Raspberry Pi and turn it on, the red LED on it starts blinking and it can't boot! I searched and found that it indicates that the power supply is messed up but I am using the official power supply! Also, I know that the Pi is not broken because it is working with the 2 channel relay and LEDs I have! This happens every time I connect the DHT11 sensor! [![The connections][2]][2]
Also, I tried wiring it again and it got heated up! How can I get it to work?
(2) https://raspberrypi.stackexchange.com/questions/97949/circuit-wiring-issue
(3) https://raspberrypi.stackexchange.com/questions/96560/dht11-sensor-and-the-wrong-voltage-may-have-fried-my-rpi3
(4) https://raspberrypi.stackexchange.com/questions/102234/gpio-pin-turns-off-immediately-when-switch-is-connected-turns-back-on-when-disc
– tlfong01 Sep 25 '19 at 11:55
