I am trying to read a signal coming from an external circuit thru the use of raspberry pi's gpio. the signal I am trying to read is a 3.3V signal coming from a voltage divider circuit. this circuit also has an external power source (not coming from Rpi both VCC and GND.) I'm a bit lost to what I am missing. Thanks!
Asked
Active
Viewed 757 times
Have you connected the grounds of the Pi and the external device? – joan Apr 16 '19 at 03:24
@joan yep I connected the ground of the pi and the externad device. I noticed that when I turned on the external device. the Rpi I'm using is somehow turned off. that is I am using a VNC viewer to view that behavior of my code. but as I mentioned when I turn on the device that Rpi is disconnected. – Rikku Apr 16 '19 at 04:33
It's worrying if the Pi switches off. That suggest a serious problem with the wiring. Clear photos showing the wiring may help. – joan Apr 16 '19 at 08:23
@joan The Pi didn't actually turned off. I only assumed that it was not functioning normally. during my testing earlier, I connected the signal from the device 3x and the VNC viewer got disconnected 3x also. so I assumed that that was the case. – Rikku Apr 16 '19 at 11:31
-1
read signal from external circuit by Rpi GPIO
signal is 3.3V from voltage divider
circuit divider circuit has external power not Rpi
Well, if the divider Vcc is 5V or higher, there is risk that the Rpi will be fried, or life shortened. The cause is usually called the "latch up" effect, when Rpi GPIO is connected by a resistor to 5V or higher, as illustrated below.
A way to get around is to use a digital buffer between Rpi GPIO and the signal to read.
Update2019apr22hkt1559
And if you wish to measure AC/DC current of motor/pump/batteries, you might like to read my answers of the following posts.
The Pumps to measure current flowing
- 3
- 10
- 24
Comments are not for extended discussion; this conversation has been moved to chat. – goldilocks Jun 18 '19 at 15:23
