How can I configure usb port available in raspberry pi to OTG ?
Asked
Active
Viewed 2,300 times
If you skim through this you will find some links: https://raspberrypi.stackexchange.com/questions/100583/where-is-the-usb2-otg-port-on-the-rpi-4-model-b-located – goldilocks Jun 24 '21 at 13:46
the TLDR of it is ... it's the USB C power port that can be OTG on the pi 4 – Jaromanda X Jun 25 '21 at 02:27
did you read goldilocks link? do that – Jaromanda X Jun 25 '21 at 03:17
1@KA No, that isn't possible. – Ingo Jun 25 '21 at 10:18
The USB2 OTG port is inside the USB-C connector so you may have to do some "special" hardware setup to use OTG Gadget mode, if you mean that. You can find more information at Where is the USB2 OTG port on the RPi 4 Model B located?. I may also be of interest How to make a splitter cable for the USB2 OTG port on the RPi 4B?.
- 42,107
- 20
- 85
- 197
