This is not an answer - it's a sequence of journal entries, or just a rambling blog if you prefer!
This doesn't meet SE standards for an answer. Yet, the objective stated in the question above has been met through the steps listed below. I'm posting this as a "prototype answer", which I'll define as a container for information that is useful and pertinent to a proper SE answer. Once a proper SE answer is posted, this material will be moved to my GitHub page. ICYI, further details are posted in a chat session between myself and @ukBaz - who should get credit for the positive result.
0. Is Bluetooth Crippled in the Lite version Raspbian/RPi OS?
@ukBaz brought this up in the discussion, and now with the benefit of hindsight, it seems clear that he's correct. In addition to the approach outlined below, other "solutions" have been posted that require installation of the pulseaudio-module-bluetooth package. Early on, I couldn't imagine why a package that's 670 MB - with ~100 dependencies, including several X libraries - would be required to play a music file over a BT link. But it seems RPi OS Lite must have PulseAudio to enable music-over-Bluetooth! It has been said the ALSA package is an alternative to PulseAudio, but that hasn't been demonstrated. Finally, it is disappointing that the functional limits of the RPi OS Lite distro aren't covered in the official documentation. Analysis and comments are welcome.
1. Are root privileges required to start bluetoothctl? (Partial answer)
For reasons that are presently unclear, the pi user's privileges are different on a Raspbian Desktop installation than they are on a Raspbian Lite installation! For example, user pi on a Desktop RPi system is able to start and control the default Bluetooth controller using bluetoothctl, but not on a Lite RPi system.
As a solution, some posts online suggest starting bluetoothctl with sudo (a.k.a. root privileges). That may be one way to do it, but other posts suggest that user pi be added to the supplementary group named bluetooth.
You can verify this:
1.1 On Raspbian Desktop, using the CLI:
pi@raspberrypi4b:~ $ bluetoothctl
Agent registered
[bluetooth]# list
Controller DC:A6:32:01:02:03 raspberrypi4b [default]
The Controller is active & responsive
1.2 On Raspbian Lite, using the CLI:
[bluetooth]# list
No default controller available
The Controller is non-responsive
1.3 The Resolution:
Add user pi to group bluetooth:
pi@raspberrypi4b:~ $ sudo usermod -G bluetooth -a pi
Verify:
getent group | grep bluetooth
bluetooth:x:112:pi
Following a reboot, user pi should find bluetoothctl and the Controller responsive without resort to sudo privilege elevation. Analysis and comments are welcome.
2. Error: Failed to connect: org.bluez.Error.Failed (Partial Answer)
This error is displayed in the bluetoothctl dialog. This error has now been resolved, but will be re-visited in the future. and is currently un-resolved. The error is displayed after the BT Speaker is trusted and paired with the controller (see command sequence in the Question above). It's a meaningless error message in the sense that it provides no clues for troubleshooting.
Based on another useful suggest from @ukBaz, the btmon utility was enlisted in an effort to get useful clues for the RPi's failure to make a successful connection to the Bluetooth speaker:
$ sudo btmon -t
Bluetooth monitor ver 5.50
= Note: Linux version 5.4.51-v7l+ (armv7l)
= bluetoothd: a2dp-sink profile connect failed for B8:F6:53:12:13:F1: Protocol not available
btmon appears to be a useful tool. The system docs are very lean, but the Ubuntu project has a decent wiki on btmon that is helpful
2.1 a2dp-sink profile connect failed Protocol not available
Using this error as a search term suggested that the solution involved installation of additional software (REF 1, REF2). The name of the software is pulseaudio-module-bluetooth.
Another source, REF 3 suggested that BlueAlsa was a better alternative to PulseAudio. It appears that PulseAudio may be more widely used, so we'll use it for this pass.
2.2 Install pulseaudio-module-bluetooth
Following the obligatory sudo apt update && sudo apt upgrade -y, the trusty apt was set to the installation of this package:
pi@raspberrypi4b:~ $ sudo apt install pulseaudio-module-bluetooth
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
dbus-user-session fontconfig libaom0 libasound2-plugins libasyncns0 libavcodec58 libavresample4 libavutil56 libcairo2 libcodec2-0.8.1 libcroco3
0 upgraded, 102 newly installed, 0 to remove and 0 not upgraded.
Need to get 46.7 MB of archives.
After this operation, 670 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Probably a good idea to reboot at this point.
This seems a staggering amount of disk space (670MB) to stream music files over a Bluetooth link. By comparison, df -H says the entire Raspberry Pi OS (32-bit) Lite installation occupies a bit less than 1,500 MB. That's quite a lot of stuff, and includes numerous dependencies on X window libs - whose utility in the Lite system is unclear. Nevertheless, we'll proceed with this pulseaudio-module-bluetooth approach now, but revisit it for a leaner solution.
The Debian project has an overview page for pulseaudio-module-bluetooth that's an easy read.
2.3 Start the pulseaudio server
If it's not clear, pulseaudio-module-bluetooth is a module in the PulseAudio "family". In fact, installing pulseaudio-module-bluetooth also installed pulseaudio as a "dependency".
For those who are interested, the document 'PulseAudio under the hood' provides a fairly extensive "introduction" to PulseAudio (TL;DR). The Debian overview on PulseAudio is brief & to the point. PulseAudio also has a Wikipedia page that's worth reading. One useful bit of trivia from Wikipedia is that the author of PulseAudio (Lennart Poettering) is also the author of systemd and avahi :0
At a more mundane level, it's also worth noting that the Debian overview on PulseAudio suggests PulseAudio has undergone major changes since jessie. Change is good.
It seems likely that the pulseaudio server would be started by systemd on those distributions that include it. But that's not the case with RPiOS Lite, so we'll do it manually:
pi@raspberrypi4b:~ $ pulseaudio --start
2.4 Test for RPi - Bluetooth connection
Before attempting the connection, start bluetoothctl to see if the Controller has any additional capabilities that may cause a different outcome:
pi@raspberrypi4b:~ pi@raspberrypi4b:~ $ bluetoothctl
Agent registered
[bluetooth]# list
Controller DC:A6:32:02:F0:97 raspberrypi4b [default]
[bluetooth]# show
Controller DC:A6:32:02:F0:97 (public)
Alias: raspberrypi4b
Class: 0x000c0000
Powered: yes
Discoverable: no
Pairable: yes
UUID: Headset AG (00001112-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d0532
Discovering: no
[bluetooth]# devices
Device B8:F6:53:12:13:F1 JBL Flip 5
[bluetooth]# info B8:F6:53:12:13:F1
Device B8:F6:53:12:13:F1 (public)
Name: JBL Flip 5
Alias: JBL Flip 5
Class: 0x00240414
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
ManufacturerData Key: 0x0057
ManufacturerData Value:
31 1f 01 18 8d 00 1.....
ServiceData Key: 0000fddf-0000-1000-8000-00805f9b34fb
This looks promising - the Controller (RPi) now has Audio Source and a few other capabilities that may be useful. The BT speaker remains paired and trusted. Let's turn the speaker on & try to connect:
Interestingly, immediately after pushing the power button on the speaker JBL Flip 5, it connected without a request (is this trust or what? :)
[CHG] Device B8:F6:53:12:13:F1 Connected: yes
[JBL Flip 5]# info B8:F6:53:12:13:F1
Name: JBL Flip 5
Alias: JBL Flip 5
Class: 0x00240414
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Advanced Audio Distribu.. (0000110d-0000-1000-8000-00805f9b34fb)
And so it seems we have made progress! In the next "chapter" below, we'll attempt to actually stream & play music over the speaker - the final objective for this installment.
2.5 The Resolution:
Install pulseaudio-module-bluetooth (and all of its dependencies).
pi@raspberrypi4b:~ sudo apt update && sudo apt upgrade -y
pi@raspberrypi4b:~ sudo apt install pulseaudio-module-bluetooth
Other potential solutions will be evaluated in the future. Analysis and comments are welcome.
3. Stream & play music from RPi to Bluetooth speaker
With a little help from my friends, esp @ukBaz, I am now enjoying Dizzy Gillespie's "Night in Tunisia" being streamed from an RPi 4 "Lite" to the Bluetooth speaker on my desk! Here's the "blow-by-blow" account of this final phase of this "answer":
3.1 mpg321 gives me nothing!
After successfully connecting the Bluetooth stack in PulseAudio on the RPi 4 to a 'JBL Flip 5' speaker, I imagined for a few minutes that I was one step away from nirvana. It wasn't quite that straightforward:
I wanted a command-line music player that could handle MP3-encoded files, and the quaint application mpg321 appeared. Install, review man mpg321, and run:
pi@raspberrypi4b:~ $ sudo apt update && sudo apt upgrade -y
pi@raspberrypi4b:~ $ sudo apt install mpg321
pi@raspberrypi4b:~ $ man mpg321
pi@raspberrypi4b:~ $ mpg321 -g 50 NightTunisia.mp3
... (crickets)
So - no error messages, but no music either!
3.2 connect speaker with cable (aka configure PulseAudio)
And once again, @ukBaz provides the guidance:
How do you select which output (card) the audio is going to?
Does this help? https://wiki.archlinux.org/index.php/PulseAudio/Examples#Set_the_default_output_sink
Indeed it does! Arch Linux has perhaps the best, most up-to-date documentation on all things Linux on the Internet today. The Arch Linux Wiki in particular is a valuable resource! And so, after a couple of tries, it was learned that this is the magic spell that connects the speaker wires from the RPi to the Bluetooth speaker :
pacmd "set-default-source bluez_sink.B8_F6_53_12_13_F1.a2dp_sink.monitor"
Some explanation is in order here as the PulseAudio CLI is incomprehensible to all but the PA-cognoscenti. Unfortunately, I am unable to offer a cogent explanation! Here's the best I can do for now:
The PulseAudio concept of sources and sinks is the first thing that escapes me. While it accomplished the objective, the command pacmd "set-default-source... strikes me as backwards: The RPi should be the source, and the speaker should be the sink!
Pondering this, while perusing man pacmd and man pulse-cli-syntax didn't provide any revelations, but it did lead me to try this:
pi@raspberrypi4b:~ $ pacmd list | grep -e 'index:' -e 'name:'
Default sink name: bluez_sink.B8_F6_53_12_13_F1.a2dp_sink
Default source name: bluez_sink.B8_F6_53_12_13_F1.a2dp_sink.monitor
While this doesn't actually explain anything, it seems apparent that source and sink are software abstractions, and need not have any relevance to the physical world. Yeah - that's weak, but it's all I've got for now, and I am rapidly becoming bored with this :)
3.3 The Resolution:
Now that PulseAudio hopefully has its inputs and outputs connected properly, it's time to give mpg321 another try:
High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
now maintained by Nanakos Chrysostomos and others.
Uses code from various people. See 'README' for more!
THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
Title : A Night In Tunisia Artist : Dizzy Gillespie & Charlie Park
Album : Town Hall, New York City, June Year : 2005
Playing MPEG stream from NightTunisia.mp3 ...
MPEG 1.0 layer III, 128 kbit/s, 44100 Hz joint-stereo
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
[7:34] Decoding of NightTunisia.mp3 finished.
It works, and the sound quality is impressive! There are numerous reports scattered around the Internet stating that the RPi audio playback on Bluetooth is scratchy, noisy and unacceptable. To my ears, the playback of "Night in Tunisia" sourced from this RPi 4 sounded at least as good as good as the playback from my Ubuntu 20.04 system hosted on a 2011 Macbook Pro. Of course that was 5 days ago, so the setup was a bit longer than the 3-4 minutes required for setup on an Ubuntu Desktop - but who's counting?
Firmware Epilogue:
I'm posting this as an edit because I recall reading that some have speculated the RPi 4 firmware may have something to do with the sound quality issues reported for the RPi. When I posted the Question, the firmware was up-to-date. However, I have just checked, and it seems a new revision has been released since this saga began:
pi@raspberrypi4b:~ $ sudo rpi-eeprom-update
BCM2711 detected
Dedicated VL805 EEPROM detected
*** UPDATE AVAILABLE ***
BOOTLOADER: update available
CURRENT: Mon 15 Jun 13:36:19 UTC 2020 (1592228179)
LATEST: Thu 3 Sep 12:11:43 UTC 2020 (1599135103)
FW DIR: /lib/firmware/raspberrypi/bootloader/critical
VL805: update available
CURRENT: 000137ad
LATEST: 000138a1
trustcommand ... you did not say anything about using "trust" – jsotola Sep 11 '20 at 06:46bluetoothctlrelies onD-Buswhich doesn't always get started correctly in the lite version. I wrote some notes on connecting to Bluetooth speakers a couple years ago that might have something of interest: https://ukbaz.github.io/howto/Bluetooth_speakers.html Any tutorial that uses one of the eight deprecated BlueZ tools should probably be avoided (https://git.kernel.org/pub/scm/bluetooth/bluez.git/commit/?id=b1eb2c4cd057624312e0412f6c4be000f7fc3617) – ukBaz Sep 11 '20 at 06:49trustto the speaker; it doesn't show in this output, but it does in others. – Seamus Sep 11 '20 at 06:56Liteversion. – Seamus Sep 11 '20 at 06:57agent ongetsAgent registered, but I getAgent registration enabled. No extra work done to start services... I don't have a desktop RPi. Not to seem stubborn, but I feel this should work inLiteas well asDesktop. Why wouldn't it? Nevertheless - a v. good observation! – Seamus Sep 11 '20 at 07:13sudo usermod -G bluetooth -a piseems to have helped startingbluetoothctl! Unfortunately, immediately aftertrustandpair, the speaker immediately falls back toServicesResolved: noandConnected: no:( – Seamus Sep 11 '20 at 07:37ServicesResolved: noandConnected: no. Pairing is exchanging security keys.connectis where it should stay connected so that you can play the music. – ukBaz Sep 11 '20 at 07:40
