I am currently trying to create a script to connect a Bluetooth printer to my raspberry device using CLI commands. So far I have tried using bluetoothctl but it freezes/crashes whenever I try to connect. Here are the steps I've been doing:
First, I search for the device's MAC address.
pi@raspberrypi:~ $ hcitool scan
Scanning ...
    66:22:EA:B3:EA:18   BlueTooth Printer
Then, I open bluetoothctl command and try to pair/connect with the device.
pi@raspberrypi:~ $ sudo bluetoothctl
[bluetooth]# agent on
Agent is already registered
[bluetooth]# scan on
[bluetooth]# pair 66:22:EA:B3:EA:18
Attempting to pair with 66:22:EA:B3:EA:18
[CHG] Device 66:22:EA:B3:EA:18 Connected: yes
[CHG] Device 66:22:EA:B3:EA:18 Connected: no
Failed to pair: org.bluez.Error.AlreadyExists # it was paired before, but if I pair them for the first time the device won't be connected.
[bluetooth]# connect 66:22:EA:B3:EA:18
Attempting to connect to 66:22:EA:B3:EA:18
Connection successful
Agent unregistered
[DEL] Controller B8:27:EB:D7:52:CA raspberrypi [default]
[bluetooth]#
In the end, I received this Bluetooth empty prompt that is frozen. If I enter bluetoothctl again I still can't enter any command. The only way to make it responsive is to restart the Bluetooth service.
sudo service bluetooth restart
I have used journalctl -f -u bluetooth.service and sudo btmon to read the logs:
pi@raspberrypi:~ $ sudo btmon
Bluetooth monitor ver 5.50
= Note: Linux version 5.4.79+ (armv6l)                                 0.945328
= Note: Bluetooth subsystem version 2.22                               0.945347
= New Index: B8:27:EB:D7:52:CA (Primary,UART,hci0)              [hci0] 0.945356
= Open Index: B8:27:EB:D7:52:CA                                 [hci0] 0.945362
= Index Info: B8:27:EB:D7:52:CA (Broadcom Corporation)          [hci0] 0.945369
@ MGMT Open: bluetoothd (privileged) version 1.14             {0x0001} 0.945377
@ MGMT Open: btmon (privileged) version 1.14                  {0x0002} 0.945534
pi@raspberrypi:~ $ journalctl -f -u bluetooth.service
-- Logs begin at Thu 2021-01-14 20:17:02 GMT. --
Jan 16 12:52:11 raspberrypi systemd[1]: Starting Bluetooth service...
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Bluetooth daemon 5.50
Jan 16 12:52:12 raspberrypi systemd[1]: Started Bluetooth service.
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Starting SDP server
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Bluetooth management interface 1.14 initialized
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Sap driver initialization failed.
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: sap-server: Operation not permitted (1)
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Failed to set privacy: Rejected (0x0b)
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Endpoint registered: sender=:1.27 path=/MediaEndpoint/A2DPSource
Jan 16 12:52:12 raspberrypi bluetoothd[7535]: Endpoint registered: sender=:1.27 path=/MediaEndpoint/A2DPSink
If I modify from the file /etc/systemd/system/bluetooth.target.wants/bluetooth.service the line containing ExecStart by adding --noplugin=sap, after reloading daemon and Bluetooth my raspberry will not scan any Bluetooth device.
ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
btmonlog. Did you startbtmonbefore you interacted with the printer? Do you know anything about the type of Bluetooth profile on the printer? Classic or BLE for example? What is the output frombluetoothctl info 66:22:EA:B3:EA:18. I think66:22:EA:B3:EA:18might be a Resolvable Random Private Address which eventually brought me to the following issue: https://github.com/RPi-Distro/pi-bluetooth/issues/8. The solution/workaround seems to be to restart the service with:sudo systemctl restart bluetooth.service– ukBaz Jan 17 '21 at 06:48sapplugin then you need to make the edit to/lib/systemd/system/bluetooth.servicethen dosudo systemctl daemon-reloadandsudo service bluetooth restart– ukBaz Jan 17 '21 at 07:03
