I know, there are already several questions about this, but none of them helped me. I have a rasbian installation and try to connect to my bluetooth headset.
When I run sudo bluetoothctl I can find the headset, I can pair it and I can trust it, but trying to connect I get an error:
$connect XX:XX:XX:XX:XX:21
Attempting to connect to XX:XX:XX:XX:XX:21
Failed to connect: org.bluez.Error.Failed
In the syslog (sudo cat /var/log/syslog | grep -i protocol) I see:
Jan 26 22:24:29 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:24:51 raspberrypi pulseaudio[1007]: Failed to load module "module-native-protocol-unix" (argument: ""): initialization failed.
Jan 26 22:24:53 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:24:55 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:24:56 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:26:07 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:26:20 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:26:21 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:26:23 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:32:30 raspberrypi bluetoothd[363]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:35:00 raspberrypi bluetoothd[1497]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
Jan 26 22:39:25 raspberrypi bluetoothd[1497]: a2dp-sink profile connect failed for XX:XX:XX:XX:XX:21: Protocol not available
I already tried a couple of suggested solutions, like reinstalling pulseaudio-module-bluetooth (https://askubuntu.com/a/1228816) or module loading (https://raspberrypi.stackexchange.com/a/67665 which is based on this: https://askubuntu.com/a/689297).
I still can't load the module-bluetooth-discover:
$sudo pactl load-module module-bluetooth-discover
Connection failure: Connection refused
pa_context_connect() failed: Connection refused
Any ideas?
