I want to shrink the image to minimise storage and to efficiently distribute this image to others who may have smaller SD Cards.
Many users ask how they can produce a small customised image that can be used to create new SD Cards and/or how they can shrink an image to make a compact backup of a running system.
I have found a backup tool which makes installable images on the Pi itself.
The original tool has changed, and keeps changing, so I can not guarantee the download - particularly as the changes are undocumented.
My script, below is in regular use
It also has utilities to mount and shrink images.
This may be useful to others
The documentation that comes with it is very brief so I note the following:-
- Extract the utilities into any directory and make scripts executable.
- Mount an
ext4
formatted partition on your Pi in/mnt
or/media
(any format which allows large files and is supported by Pi e.g. exFAT or a network drive can be used). - For the initial run you will be prompted for a Backup Image name e.g.
/mnt/Image/BusterBackup.img
- You will be prompted for a Image ROOT filesystem size (in MB), this can be 0 for smallest possible or blank for full backup.
For a compact image use the Used fromdf -H --type=ext4 --output=fstype,used
plus 300 - On subsequent runs enter the path of the Backup Image to incrementally update.
NOTE The image created will not auto resize on boot, and should be maximised in
raspi-config
An example of the commands I used:-
# Mount USB
sudo mount /dev/sda1 /mnt/Image/
# Mount network drive
sudo mount.cifs //10.1.2.107/Images /mnt/Image -o user=UUU
# Update backup
sudo image-utils/image-backup /mnt/Image/BusterBackup.img
# Mount backup
sudo image-utils/image-mount /mnt/Image/BusterBackup.img MountedImages
When done, run:
sudo umount MountedImages; sudo losetup -d /dev/loop0
# Compress backup
sudo gzip -9kN /mnt/Image/StretchBackup.img
I have slightly modified the original image-backup
(to copy mountpoints), to correctly calculate partition offsets and sizes and added a couple of comments.
#!/bin/bash
# Original https://raspberrypi.org/forums/viewtopic.php?p=1528736
# 2019-09-26 Modified to set size of boot sector
trap '{ stty sane; echo ""; errexit "Aborted"; }' SIGINT SIGTERM
ADDBLK=0
Set BOOT_SIZE_MB to the Desired boot sector size (in MB) - should be multiple of 4MB
BOOT_SIZE_MB=256
BOOTSIZEM=$BOOT_SIZE_MB'M'
BOOTBEG=8192
BOOT_SIZE="$((BOOT_SIZE_MB * 1024 * 1024))"
ROUND_SIZE="$((4 * 1024 * 1024))"
Ensure root sector starts on an Erase Block Boundary (4MB)
ROOTBEG=$(((BOOT_SIZE + ROUND_SIZE -1) / ROUND_SIZE * ROUND_SIZE / 512 + BOOTBEG))
MNTPATH="/tmp/img-backup-mnt"
ONEMB=$((1024 * 1024))
create BOOT loop device
mkloop1()
local INFO1=""
local SIZE1=0
local START1=0
sync
INFO1="$(sfdisk -d "${IMGFILE}")"
START1=$(grep type=c <<< "${INFO1}" | sed -n 's|^.start=\s+([0-9]+).$|\1|p')
SIZE1=$(grep type=c <<< "${INFO1}" | sed -n 's|^.size=\s+([0-9]+).$|\1|p')
LOOP1="$(losetup -f --show -o $((${START1} * 512)) --sizelimit $((${SIZE1} * 512)) "${IMGFILE}")"
if [ $? -ne 0 ]; then
errexit "Unable to create BOOT loop device"
fi
rmloop1()
if [ "${LOOP1}" != "" ]; then
sync
losetup -d "${LOOP1}"
LOOP1=""
fi
create ROOT loop device
mkloop2()
local INFO2=""
local SIZE2=0
local START2=0
sync
INFO2="$(sfdisk -d "${IMGFILE}")"
START2=$(grep type=83 <<< "${INFO2}" | sed -n 's|^.start=\s+([0-9]+).$|\1|p')
SIZE2=$(grep type=83 <<< "${INFO2}" | sed -n 's|^.size=\s+([0-9]+).$|\1|p')
LOOP2="$(losetup -f --show -o $((${START2} * 512)) --sizelimit $((${SIZE2} * 512)) "${IMGFILE}")"
errexit "Unable to create ROOT loop device"
fi
rmloop2()
if [ "${LOOP2}" != "" ]; then
sync
losetup -d "${LOOP2}"
LOOP2=""
fi
Mount Image partitions
mntimg()
MNTED=TRUE
if [ ! -d "${MNTPATH}/" ]; then
mkdir "${MNTPATH}/"
errexit "Unable to make ROOT partition mount point"
fi
fi
mkloop2
mount "${LOOP2}" "${MNTPATH}/"
errexit "Unable to mount image ROOT partition"
fi
if [ ! -d "${MNTPATH}/boot/" ]; then
mkdir -p "${MNTPATH}/boot/"
errexit "Unable to make BOOT partition mount point"
fi
fi
mkloop1
mount "${LOOP1}" "${MNTPATH}/boot/"
errexit "Unable to mount image BOOT partition"
fi
umntimg()
umount "${MNTPATH}/boot/"
errexit "Unable to unmount image BOOT partition"
fi
rmloop1
umount "${MNTPATH}/"
errexit "Unable to unmount image ROOT partition"
fi
rmloop2
rm -r "${MNTPATH}/"
MNTED=FALSE
errexit()
echo ""
echo "$1"
echo ""
if [ "${MNTED}" = "TRUE" ]; then
umount "${MNTPATH}/boot/" &> /dev/null
umount "${MNTPATH}/" &> /dev/null
rm -rf "${MNTPATH}/" &> /dev/null
fi
rmloop1
rmloop2
exit 1
LOOP1=""
LOOP2=""
MNTED=FALSE
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
if [ $(id -u) -ne 0 ]; then
errexit "$0 must be run as root user"
fi
PGMNAME="$(basename $0)"
for PID in $(pidof -x -o %PPID "${PGMNAME}"); do
if [ ${PID} -ne $$ ]; then
errexit "${PGMNAME} is already running"
fi
done
rsync --version &> /dev/null
errexit "rsync not installed (run: apt-get install rsync)"
fi
if command -v systemctl > /dev/null && systemctl | grep -q '-.mount'; then
SYSTEMD=1
elif [ -f /etc/init.d/cron ] && [ ! -h /etc/init.d/cron ]; then
SYSTEMD=0
else
errexit "Unrecognized init system"
fi
if [ ${SYSTEMD} -eq 1 ]; then
ROOT_PART="$(mount | sed -n 's|^/dev/(.) on / .|\1|p')"
else
if [ ! -h /dev/root ]; then
errexit "/dev/root does not exist or is not a symlink"
fi
ROOT_PART="$(readlink /dev/root)"
fi
ROOT_TYPE=$(blkid "/dev/${ROOT_PART}" | sed -n 's|^.TYPE="(\S+)".|\1|p')
ROOT_DEV="${ROOT_PART:0:(${#ROOT_PART} - 1)}"
if [ "${ROOT_DEV}" = "mmcblk0p" ]; then
ROOT_DEV="${ROOT_DEV:0:(${#ROOT_DEV} - 1)}"
fi
PTUUID="$(blkid "/dev/${ROOT_DEV}" | sed -n 's|^.PTUUID="(\S+)".|\1|p')"
DEVSIZE=$(blockdev --getsize64 "/dev/${ROOT_PART}")
BLKSIZE=$(blockdev --getbsz "/dev/${ROOT_PART}")
BLKCNT=$((${DEVSIZE} / ${BLKSIZE}))
INFO="$(df | grep /dev/root)"
DFKSIZE=$(awk '{print $2}' <<< "${INFO}")
DFKFREE=$(awk '{print $4}' <<< "${INFO}")
ROOTSIZE=$((${BLKCNT} * ${BLKSIZE}))
ROOTUSED=$(((${DFKSIZE} - ${DFKFREE}) * 1024))
IRFSMIN=$(((${ROOTUSED} + (${ADDBLK} * ${BLKSIZE}) + (${ONEMB} - 1)) / ${ONEMB}))
IRFSMAX=$(((${ROOTSIZE} + (${ONEMB} - 1)) / ${ONEMB}))
IMGFILE="$1"
if [ "${IMGFILE}" = "" ]; then
Create Image file
while :
do
echo ""
read -r -e -i "${IMGFILE}" -p "Image file to create? " IMGFILE
continue
elif [[ ! "${IMGFILE}" =~ ^/mnt/.$ && ! "${IMGFILE}" =~ ^/media/.$ ]]; then
echo ""
echo "${IMGFILE} does not begin with /mnt/ or /media/"
continue
fi
if [ -d "${IMGFILE}" ]; then
echo ""
echo "${IMGFILE} is a directory"
elif [ -f "${IMGFILE}" ]; then
echo ""
echo -n "${IMGFILE} already exists, Ok to delete (y/n)? "
while read -r -n 1 -s answer; do
if [[ "${answer}" = [yYnN] ]]; then
echo "${answer}"
if [[ "${answer}" = [yY] ]]; then
break 2
else
break 1
fi
fi
done
else
break
fi
done
IRFSSIZE=""
while :
do
echo ""
read -r -e -i "${IRFSSIZE}" -p "Image ROOT filesystem size (MB) [${IRFSMAX}]? " IRFSSIZE
if [ "${IRFSSIZE}" = "" ]; then
IRFSSIZE=${IRFSMAX}
break
elif [ ${IRFSSIZE} -ge ${IRFSMIN} ]; then
break
else
echo ""
echo "Requested image ROOT filesystem size (${IRFSSIZE}) is too small (Minimum = ${IRFSMIN})"
IRFSSIZE=${IRFSMIN}
fi
done
echo ""
echo -n "Create ${IMGFILE} [${IRFSSIZE} MB] (y/n)? "
echo "${answer}"
break
else
errexit "Aborted"
fi
fi
done
rm "${IMGFILE}"
errexit "Unable to delete existing image file"
fi
fi
ROOTEND=$((${ROOTBEG} + ((${IRFSSIZE} * ${ONEMB}) / 512) - 1))
truncate -s $(((${ROOTEND} + 1) * 512)) "${IMGFILE}"
errexit "Unable to create image file"
fi
create image/partitions
sync
fdisk "${IMGFILE}" <<EOF > /dev/null
p
n
p
${BOOTBEG}
+${BOOTSIZEM}
t
c
p
n
p
${ROOTBEG}
${ROOTEND}
p
w
EOF
mkloop1
mkloop2
mkfs.vfat "${LOOP1}" > /dev/null
errexit "Unable to create image BOOT filesystem"
fi
dosfsck "${LOOP1}" > /dev/null
errexit "Image BOOT filesystem appears corrupted"
fi
if [ "${ROOT_TYPE}" = "f2fs" ]; then
mkfs.f2fs "${LOOP2}" > /dev/null
else
mkfs.ext4 -q -b ${BLKSIZE} "${LOOP2}" > /dev/null
fi
errexit "Unable to create image ROOT filesystem"
fi
rmloop2
rmloop1
Initialise image PARTUUID
p
x
i
0x${PTUUID}
r
p
w
EOF
Create empty directories in image root partition
mntimg
mkdir "${MNTPATH}/dev/" "${MNTPATH}/media/" "${MNTPATH}/mnt/" "${MNTPATH}/proc/" "${MNTPATH}/run/" "${MNTPATH}/sys/" "${MNTPATH}/tmp/"
errexit "Unable to create image directories"
fi
chmod a+rwxt "${MNTPATH}/tmp/"
umntimg
echo ""
echo "Starting full backup (for incremental backups, run: $0 ${IMGFILE})"
END of create image/partitions
else
Check existing Image
errexit "${IMGFILE} does not begin with /mnt/ or /media/"
fi
errexit "${IMGFILE} is a directory"
elif [ ! -f "${IMGFILE}" ]; then
errexit "${IMGFILE} not found"
fi
echo "Starting incremental backup to ${IMGFILE}"
fi
rsync root partition
mntimg
sync
rsync -aDH --partial --numeric-ids --delete --force --exclude "${MNTPATH}" --exclude '/dev' --exclude '/media' --exclude '/mnt//' --exclude '/proc' --exclude '/run' --exclude '/sys'
--exclude '/tmp' --exclude 'lost+found' --exclude '/etc/udev/rules.d/70-persistent-net.rules' --exclude '/var/lib/asterisk/astdb.sqlite3-journal' / "${MNTPATH}/"
if [[ $? -ne 0 && $? -ne 24 ]]; then
errexit "Unable to create backup"
fi
sync
umntimg
- 59,890
- 31
- 101
- 209
rsync
code is quite standard and once you have an image updates are fast and safe. – Milliways Jun 27 '22 at 01:46
