After some errors on the many pis I manage with raspbian buster, I had some no space left on device issues and saw that the /boot partition has only 54M /dev/mmcblk0p1 43M 23M 21M 53% /boot. I resized it after having moved and shrinked the / partition with gparted. On resizing the /boot partition gparted threw me an error but seemed to have done something anyways... I now want to resize2fs /dev/mmcblk0p1 but it doesnt' work
sudo resize2fs /dev/mmcblk0p1
resize2fs 1.43.4 (31-Jan-2017)
resize2fs: Bad magic number in super-block while trying to open /dev/mmcblk0p1
Couldn't find valid filesystem superblock.
Philippe Gachoud
  • 277
resize2fs will resize ext2,ext3 and ext4 filesystems. Your boot partition is not any of those. It is a vfat. Therefore fatresize is the command to use.
Call me paranoid, but your remark:
gave me the idea that something is not going as you planned.
Shrinking the root partition takes room at the end. The /boot is at the beginning. So probably, the /boot and the root partition are still contiguous and therefore, the partition for /boot is probably not enlarged (which might be the error message) and therefore, fatresize will probably do nothing. But that is just based on what I have in my Pis.
Ljm Dullaart
  • 2,491
  • thx, see my complete answer, at the end donno if its about gparted version I have but had to delete/recreate/restore-data for the /boot partition – Philippe Gachoud Aug 13 '20 at 23:40
You have presumably "updated" from a previous release - which is NOT supported.
Buster needs a larger boot partition.
You CAN NOT do this on the Pi although it can be done on a Linux computer.
You should do a fresh install.
If you search this Forum you will find similar questions.
  • Of course, but if you have hours configuring an image it worths doing an update and grow the boot partition.... I cannot afford doing a new image every time a new release gets out.... but thx, I saw it too! – Philippe Gachoud Aug 13 '20 at 23:35
    @PhilippeGachoud New OS are only released every 2 years or so (Raspbian is on its 4th release since 2012) and it takes longer to "fix" than a fresh install, but if you want to do this see https://raspberrypi.stackexchange.com/a/114556/8697 – Milliways Aug 14 '20 at 00:03
Actually, the solution was to resize the boot partition after resizing the slash partition smaller and move it right. Resizing the boot partition needs a
  1. mount partition on /tmp/some_dir
  2. copy data to it cp -rp /mnt/mounted_boot_partition/* /tmp/some_dir/
  3. delete the partition with gparted or any other tool
  4. create a bigger partition with boot flag (am not sure its mandatory)
  5. restore data cp -rp /tmp/some_dir/* /mnt/mounted_boot_partition/
  6. umount sync && /mnt/mounted_boot_partition/
  7. try it!
Philippe Gachoud
  • 277
  • Please mark the answer as the accepted one with a click on the tick on its left side. That prevents your Question from being shown as a unsolved Post to the community and saves them/us a lot of work. – Ingo Aug 18 '20 at 21:43
