I have a Raspbian Buster install on my Raspberry Pi Model B (1st gen). The Raspi had problems with freezes and booting so I figured, it's time for an upgrade and bought a Raspberry Pi 4. Turned out, the old Raspi is ok, just the SD card is starting to fail. So, I'd like to move my Raspbian install to the new SD card anyway.
The problem is, the old SD card is failing and I cannot dd the partition from the old to the new SD card (the copying speed gets very low at some point and file system errors pop up). So I did a clean new Raspbian install using the RaspberryPi Imager (nice simple tool btw.) and would like to:
  1. Export a list of explicitly installed packages from the old to the new install. I have SSH access to the old install, it mostly freezes only around once a week, so I can use apt or any other CLI tool. In the Arch Linux universe I would do a "pacman -Qe" and get a list of all explicitly installed packages, but on Raspbian I'm a bit stuck with this. Web search gives mostly rather old and cumbersome results. Is there any reliable way to get a list of explicitly installed packages which is easy to reuse for installing them on the new Raspbian install?
  2. Copy data, system and user configuration. I thought about copying /var/www, /etc, and /home from the old install to the new one. I put a lot of effort into configuring stuff (webserver with Let's Encrypt and a DynDNS IP update script, local print server, local file sharing via NFS, Syncthing, git repository etc). Would like to just copy anything user created and not bother setting everything up again. Is this likely gonna work?
Thanks for any input!
Photon
  • 145
    Replicating installed packages on a Debian-based system -> howto. Regarding the data copying: should be fine, you might have to update a few things: e.g. fstab (new UUIDs), new network interface names (e.g. eth0) etc. but most of it could work out (no guarantee). Make sure that both systems are upgraded to the latest version to ensure same libraries etc. and that you are 100% sure that you did not introduce configurations in other places. Best create backups of /etc on a different drive. – FelixJN Dec 03 '20 at 14:22
  • apt list --installed – goldilocks Dec 03 '20 at 23:42
  • It turned out that my old Raspi ran Debian 9, while I had installed Debian 10 on the new one. So I ended up going through the list of installed packages by hand and installing those which were relevant for stuff I had set up. Then did a diff on /etc and went through it to copy/merge all config files which I knew were relevant. Not the most elegant solution but it worked somehow... – Photon Dec 28 '20 at 12:38
I have modified my apthist script to show only user installed packages.
#!/bin/bash
#Print apt-get history EXCEPT for upgrades
# 2017-08-06
# 2020-10-07    Include packages installed by packagekit
# 2020-12-04    delete lines containing 'apt upgrade' and preceding line
for logf in $(ls /var/log/apt/history.log..gz | sort -rV) ;
do zcat $logf | grep -E -A 1 "Start-Date:|Commandline:" | sed -e '/Requested-By:/d' ; done
| tac | sed -e '/^--/d' -e '/apt .
upgrade/{N;d;}' | tac
Include most recent
grep -E -A 1 "Start-Date:|Commandline:" /var/log/apt/history.log | sed -e '/Requested-By:/d'
| tac | sed -e '/^--/d' -e '/apt .*upgrade/{N;d;}' | tac
  1. Below is a script I use to list apt history. This is still handy if you are interested in upgrades.
#!/bin/bash
for logf in $(ls /var/log/apt/history.log.*.gz | sort -rV) ; do zcat $logf | grep -E -A 1 "Start-Date:|Commandline:" | sed -e '/Requested-By:/d' ; done
# Include most recent
This produces a more manageable list which is easily edited to remove the many "apt upgrade' etc and leave a simple list.
There are some limitations;
  1. only the last 12 months are shown (because the logs are rotated monthly and only the 12 most recent are kept) but this can be extended by editing /etc/logrotate.d/apt
The following script uses the history produced by the above and filters to show User history, excluding updates.
#! /bin/sh
# delete lines containing 'apt upgrade' and preceding line
# useful for finding apt history EXCEPT for upgrades
# run on output of apthist.sh
cat $1 | tac | sed -e '/^--/d' -e '/apt .*upgrade/{N;d;}' | tac
  1. You SHOULD do regular backups.
    Backup image of SD Card produces a small customised image that can be used to create new SD Cards.
    This is a file based backup, so should be immune to SD Card problems.
  2. You may also be interested in the following. I use this to synchronise my latest updated OS to a SD Card which contains an installed Raspberry Pi OS. You could use this to populate a freshly installed OS. This does not copy /home, but you could uncomment the line to include it.
#!/bin/bash
# script to synchronise Pi files to SD Card
# 2019-08-12
# 2020-09-30
# 2020-10-23    copy /home/*
This script synchronises necessary files from running OS on Pi to SD Card
SD Card (already formatted with partitions containing OS) in SD Card reader on Pi
NOTE does not copy cmdline.txt or /etc/fstab
NOTE does not copy /home/*
NOTE file rsync EXCLUDE_FILE is required
use 'rsync-dup-exclude.txt' as we WANT logs & .bash_history to be copied
EXCLUDE_FILE='rsync-dup-exclude.txt'
echo $EXCLUDE_FILE BOOT_MOUNT='/mnt/SDA1' ROOT_MOUNT='/mnt/SDA2'
Check/create Mount Points
if [ ! -e $BOOT_MOUNT ]; then mkdir $BOOT_MOUNT fi if [ ! -e $ROOT_MOUNT ]; then mkdir $ROOT_MOUNT fi echo $BOOT_MOUNT $ROOT_MOUNT
Mount Partitions
if ! $(mountpoint -q $BOOT_MOUNT); then mount /dev/sda1 $BOOT_MOUNT # mount partition containing boot files fi if ! $(mountpoint -q $ROOT_MOUNT); then mount /dev/sda2 $ROOT_MOUNT # mount root partition containing OS files fi
if $(mountpoint -q $BOOT_MOUNT) && $(mountpoint -q $ROOT_MOUNT); then echo $BOOT_MOUNT $ROOT_MOUNT echo "Synchronise boot files to SD Card" rsync -a --delete-during --exclude='cmdline.txt' --exclude='/SD?' --exclude='/SD??' /boot/ $BOOT_MOUNT/ echo "Synchronise OS files to SD Card" $ROOT_MOUNT/
rsync -axH --progress --delete-during --exclude='/etc/fstab' --exclude='/home/*' --exclude='WolframEngine' --exclude='scratch2' --exclude-from=$EXCLUDE_FILE / $ROOT_MOUNT/
rsync -axH --progress --delete-during --exclude='/etc/fstab' --exclude='WolframEngine' --exclude='scratch2' --exclude-from=$EXCLUDE_FILE / $ROOT_MOUNT/
umount $BOOT_MOUNT
umount $ROOT_MOUNT
else echo "Backup Card not available or not writable" fi
This needs to file rsync-dup-exclude.txt to exclude unnecessary files.
/proc/*
/sys/*
/dev/*
/boot/*
/tmp/*
/run/*
/mnt/*/*
/var/cache/*
/boot/cmdline.txt /etc/fstab
.Trashes ._.Trashes .fseventsd .Spotlight-V100 .DS_Store .AppleDesktop .AppleDB Network Trash Folder Temporary Items
.cache /etc/fake-hwclock.data /var/lib/rpimonitor/stat/ /etc/hostname /etc/hosts
