In Terminal its working but not working using python code.
My Code:
import serial
from time import sleep
ser = serial.Serial ("/dev/ttyS0")
while True:
received_data = ser.read()
sleep(0.03)
data_left = ser.inWaiting()
received_data += ser.read(data_left)
ser.write(received_data)
I'm trying to serial communication from Raspbian using Python to Arduino but I'm getting some permission issues like:
%Run New.py
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 265, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
PermissionError: [Errno 13] Permission denied: '/dev/ttyS0'
During handling of the above exception, another exception occurred:
File "/home/pi/Downloads/New.py", line 4, in <module>
ser = serial.Serial ("/dev/ttyS0") #Open port with baud rate
File "/usr/lib/python3/dist-packages/serial/serialutil.py", line 236, in __init__
self.open()
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 13] could not open port /dev/ttyS0: [Errno 13] **Permission denied:** '/dev/ttyS0'
If I try to communicate using terminal echo "Hello" > /dev/ttyS0 it's working. Only with the python code its creating problem.
sudo(or run the script directly withsudo python /home/pi/Downloads/New.py)? Could you add the output fromls -l /dev/ttyS0andgroupsto your answer? – Roger Jones Apr 15 '19 at 16:05
