I am fairly new to raspberry pi's and Linux so forgive me if my question is trivial.
I have been trying to install openssl and libssl via ssh on a Raspberry Pi zero that does not have access to the internet. I tried everything mentioned here and nothing worked:
And also tried to get things working on my own by first downloading the .deb files from these links:
- https://packages.debian.org/jessie-backports/armhf/openssl/download
- https://packages.debian.org/jessie-backports/armhf/libssl1.0.0/download
and then after using scp to move the files to my /usr/local/lib directory I ran the following commands:
pi@host:/usr/local/lib $ sudo dpkg -i libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb
(Reading database ... 119764 files and directories currently installed.)
Preparing to unpack libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb ...
Unpacking libssl1.0.0:armhf (1.0.2l-1~bpo8+1) over (1.0.2l-1~bpo8+1) ...
Setting up libssl1.0.0:armhf (1.0.2l-1~bpo8+1) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
pi@host:/usr/local/lib $ sudo dpkg -i openssl_1.0.2l-1~bpo8+1_armhf.deb
Preparing to unpack openssl_1.0.2l-1~bpo8+1_armhf.deb ...
Unpacking openssl (1.0.2l-1~bpo8+1) over (1.0.1t-1+deb8u7) ...
Setting up openssl (1.0.2l-1~bpo8+1) ...
Processing triggers for man-db (2.7.5-1~bpo8+1) ...
pi@host:/usr/local/lib $ sudo apt install -f
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Then I tried a different approach:
pi@host:/usr/local/lib $ sudo apt install ./libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb
Which resulted in the command line printing like a million error lines like this: (there are alot more that I didn't include but they all looked the same)
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'cantab-theme' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'cantab-wallpaper' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'fontconfig-infinality' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'gtk2-engines-clearlookspix' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'libplymouth-dev' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'libplymouth4' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'lxkeymap' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pi-greeter' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pi-package' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pi-package-session' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pi-package-data' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'piclone' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pimixer' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pipanel' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pishutdown' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pix-icons' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'rpd-icons' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pix-plym-splash' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'rpd-plym-splash' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pixel-wallpaper' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'rpd-wallpaper' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'point-rpi' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'pprompt' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'raspberrypi-ui-mods' was not found
E: Release 'libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb' for 'rc-gui' was not found
I have also run sudo apt update and sudo apt upgrade both before and after attempting to install.
Can anyone explain to me what exactly is going wrong here? Am I installing incorrectly? If yes how so? I assume that there is something really fundamental here that I don't understand? Help appreciated!
openssl version -v
? – GramThanos Feb 28 '19 at 00:03
