How do I install OpenSSL 1.0.2 version in Debian (Raspberry Pi3) OS. It just installs OpenSSL 1.0.1 automatically. I require version later than this i.e. 1.0.2* which supports DTLS.
Please help how to install latest version
If you really need it but can't obtain it from the repos, you could always try compiling from source. Install git and build-essentials (if you don't have it already) and run the following:
git clone git://git.openssl.org/openssl.git --depth 1
cd openssl
./config
make
make test
sudo make install
NOTE: On some distros (e.g. Ubuntu 19.10), you may need to run the config step as ./config --prefix=/usr. This puts the compiled binaries in /usr/bin, not /usr/local/bin.
Will this method dynamically link to /usr/bin/openssl ? Last time, I installed similarly but after installation, I could not see libssl.1.0.0 when I checked for $ ldd /usr/bin/openssl. Please help to confirm.
– Jyoti Raj Sharma May 09 '17 at 19:39/usr.
– VarunAgrawal
Jun 22 '19 at 16:58
Debian jessie-backports would contain the required openssl with version 1.0.2. However you should not directly install the package from jessie-backports since it was compiled for ARMv7-A while Raspbian is compiled for ARMv6. Luckily, you can get the source from jessie-backports and build packages with the proper compiler options for Raspbian.
Using the cross compilation toolchain described here you can proceed as follows:
Add jessie-backports sources to your apt sources list:
echo "deb-src http://httpredir.debian.org/debian jessie-backports main contrib non-free" | sudo tee /etc/apt/sources.list.d/jessie-backports.list
sudo apt update
Get the openssl source code from jessie-backports:
apt-get source openssl/jessie-backports
Build the openssl Debian packages:
cd openssl-1.0.2k/
export DEB_BUILD_OPTIONS=nocheck; debuild -us -uc -aarmhf
Copy the resulting packages to your Raspberry Pi:
scp libssl1.0.0_1.0.2k-1~bpo8+1_armhf.deb pi@raspberrypi:
scp openssl_1.0.2k-1~bpo8+1_armhf.deb pi@raspberrypi:
Enter the Raspberry Pi and install the new packages:
ssh pi@raspberrypi
sudo dpkg -i libssl1.0.0_1.0.2k-1~bpo8+1_armhf.deb
sudo dpkg -i openssl_1.0.2k-1~bpo8+1_armhf.deb
Notes:
make install.
jessie-backportsincludes 1.0.2 - never tried installing it on a pi, but you could try addingdeb http://ftp.debian.org/debian jessie-backports mainto/etc/apt/sources.list– Jaromanda X May 07 '17 at 01:52
