Start pigpiod:
I began this answer before @ben_nuttall answered. After reading @ben's answer, I feel part of my answer (below) may still add something. However, I feel @ben's answer on starting the pigpiod service is the best and simplest. For completeness, here is @ben's answer for starting pigpiod:
sudo systemctl enable pigpiod
Once pigpiod is started such that it becomes part of the normal boot sequence on your RPi, following is an approach for running your Python script at boot time.
Start Python script at boot time using cron:
There are several ways to do this. IMHO, the two "best" ways are 1) systemd, and 2) cron. The tradeoffs (again, IMHO) are that systemd is more comprehensive and technically superior, but more difficult (which only means that you'll need to invest more time learning before you can do useful things with it). I feel that cron is easier, so that's the answer I'll propose below:
- From the command line, type
man cron
Read the manual (man page) for cron. It's short, and you should have the background.
"Jobs" in cron are scheduled from a file that's called the crontab. You'll edit this file to add your "job". There's also a manual for crontab if you care to read it (you should): man crontab
Start the editor for crontab, and enter the instructions for starting your "job" on the command line of a terminal as follows:
(NOTE: I've added the $ symbol at the beginning of an input as shorthand for the bash shell prompt)
$ crontab -e
Your default editor (likely nano) will start, displaying the default contents of your crontab. Move the cursor to the beginning of the first empty line at the bottom of the editor's display. Enter the following line:
@reboot /usr/bin/python3 /home/pi/moving/moving_test.py > /home/pi/cronjoblog 2>&1
Save/Write the crontab (^O), then exit the editor (^X) to return to the shell/command line.
Note the use of complete file specifications in this entry. This is due to the fact that your crontab is not executed with the same $PATH that you will have as user pi. It's therefore a good habit to get into, even if it's not always strictly necessary. Note also the redirection of any stderr (error messages) to the file /home/pi/cronjoblog preserves this useful information for any post-op debugging that may be needed. Again, good habit.
- Reboot your RPi, and check if the Python script executed. If it did not, inspect the file
/home/pi/cronjoblog for error messages that will help isolate the problem.
Occasionally, you will find that a job you've scheduled in your crontab will persistently fail to execute, and the cause will be unclear. The issue may be due to the fact that cron does not maintain awareness of whether programs and services have actually booted before it calls them. This is typically remedied by adding a brief sleep delay to give these services time to boot before they are called. The following adds a 10 second delay to the previous line:
@reboot /bin/sleep 10; /usr/bin/python3 /home/pi/moving/moving_test.py > /home/pi/cronjoblog 2>&1
cron's lack of awareness is a shortcoming, and the primary reason that systemd is a technically superior approach. Nevertheless, cron remains useful and simple. Try this, and let us know how you get on via comments, or by editing your original question.
