Unfortunately the Q&A you are consulting is
Mostly obsolete, since the accepted answer uses SysV init style methods instead of systemd ones. These are both init systems. The former is used on v. <= 7 Raspbian (unless I am remembering wrong, there's actually no < 7 since Raspbian follows Debian version numbering, and Debian has been evolving for a few decades). The latter is used on the previous (8, jessie) and current (9, stretch) versions. It supports SysV scripts for backward compatibility, but...
The accepted answer in that Q&A does not actually explain how to write a SysV style script, just how to enable one. And that's why you get the "missing LSB tags" error. The script is missing a lot of things that would make it SysV compliant.
There's no point in learning how to write such a script, however (it is a bit ornate), since the system is obsolete.
The easiest thing to do there would be to just add something to the end of /etc/rc.local
(but before the final exit 0
line):
export PATH=/usr/local/bin:/usr/local/sbin:/bin:/sbin:/usr/bin:/usr/sbin
cd /media/root/NEW\ VOLUME/FurBot
setsid node bot.js &> /dev/null
Notice I inverted the slash in NEW\ VOLUME
. Command line parameters cannot have unescaped spaces in them; I presume that's what you mean to do. You can instead use quotes:
cd "/media/root/NEW VOLUME/FurBot"
setsid
maybe spurious here but doesn't hurt. See man setsid
for what it does.
If you want to get fancier, you can write a systemd service file for it --
you will find a lot of examples of such for node.js
online -- but if this works for you, then don't worry about it.
line do? – Phill Healey Jan 06 '20 at 18:44rc.local
here might be a bit paranoid, but harmless. – goldilocks Jan 06 '20 at 19:00
