There is a 2TB Time Capsule on my home network (IP 192.168.0.1). How can I mount the Time Capsule's disk from my Raspberry Pi, automatically after reboots?
Put it in fstab.
sudo su
mkdir /mnt/timecapsule
echo "//timeCapsuleIp/Data /mnt/timecapsule cifs user=timecapsuleUsername,pass=timecapsuleUserPassword,rw,uid=1000,iocharset=utf8,sec=ntlm 0 0" >> /etc/fstab
Required cifs-utils package should be already provided on raspbian.
Of course change timecapsuleUsername and timecapsuleUserPassword. The uid=1000 sets owner of mounted files to user pi. If using other user check it's uid with id -u username. Check if "Data" folder is right for you - list resources by issuing command smbclient -Uusername -I ip-address -L.
I got adding sec=ntlm to the options, the complete command is:
sudo su
echo "//timeCapsuleIp/Data /mnt/timecapsule cifs user= timecapsuleUsername,pass= timecapsuleUserPassword,rw,uid=1000,iocharset=utf8,sec=ntlm 0 0" >> /etc/fstab
Then, run this command:
mount -a
You should no get any errors.
Update for users of Raspberry Stretch v9. Note the addition of vers=1.0
//IPofTimeCapsule/PathWithinYourTimeCapsule /mnt/TimeCapsule cifs username=insert,password=insert,rw,uid=1000,iocharset=utf8,sec=ntlm,vers=1.0 0 0
Sorry if I wasn't clear, I meant IP address of TimeCapsule. For example, the line might read... //192.168.1.11/Data /mnt/TimeCapsule cifs username=bsmith, password=batman, rw, uid=1000, iocharset=utf8, sec=ntlm, vers=1.0 0 0 – ddavila Jan 19 '19 at 04:37
For me, when using a disk password on the time capsule, it only worked when I added uid=504 (which is the userID used on the macintosh mainly using the timecapsule, not the uid used on the raspberry). When I didn't put uid=504 then I got "mount error(16): Device or resource busy" back from the time capsule.
- 11
- 2
mount error(115): Operation now in progress. I can access the share fine with smbclient though. Any ideas? – Arne Jun 07 '14 at 17:03.localname instead of the IP, does not seem to work reliably. Second, I needed to addsec=ntlmto the options. Now it works! – Arne Jun 07 '14 at 17:14Disks Secure SharedDisksWith a disk passwordoption is selected, thenuser=param would be ignored regardless of what it's set to – Hengjie Feb 01 '16 at 09:35sec=ntlmand I can confirm that this works with disks secured with a device password as well as a disk password. – Gary Gale Jun 09 '16 at 14:58
