I tried to use the information on the other two Posts with similar questions and wasn't able to figure it out. I'm still new to this.
I am trying to mount the Time Capsule so I can use the HDD on there to store files for my Raspberry Pi.
first I tried
echo "//timeCapsuleIp/Data /mnt/timecapsule cifs user=timecapsuleUsername,pass=timecapsuleUserPassword,rw,uid=1000,iocharset=utf8 0 0" >> /etc/fstab
But that didn't work. And then I saw the mount fix using this code
//192.168.1.1/Time-Capsule /mnt/TimeCapsule cifs credentials=your_TimeCapsule_credentials_path],file_mode=0777,dir_mode=0777,rw,sec=ntlm   0   0
but I still wasn't able to get it to work.
I am also not sure how to find the username for the Time Capsule as when I use it from the Macbook it only asks for a passwork and not any username.
Ghanima
  • 15,855
  • 119
user25901
I haven't tried this out, but you might want to check out this: How to mount Time Capsule from Raspberry Pi
You'll need to install cifs-utils.
linuxgnuru
  • 625
    Odd, I have my TimeCapsule mounted just fine. On my macbook pro, my username is jwiggins. Here is the last line of my /etc/fstab file: //10.0.5.1/Data /mnt/tc cifs user=jwiggins,pass=,rw,uid=1000,iocharset=utf8,sec=ntlm 0 0 I had to create the /mnt/tc directory. The password is one I setup on the TimeCapsule when I first installed it. – linuxgnuru Jan 08 '15 at 17:06
