I followed this video tutorial which is very similar to this text tutorial to configure a pair of nRF2L01 rf radios to communicate with each other, however when the ReceivePi.py is running it results in this repeatedly (and very fast), whether or not my second raspberry pi is transmitting:
Loaded payload reply of [1]
Received: [13]
Translating the receivedMessage into unicode characters
Received: [13]
Anyone have any advice on what might be going on?
I did notice that when the script first runs it gives me this:
Data Rate    = 1MBPS
Model        = nRF24L01
CRC Length   = Disabled
PA Power     = PA_MIN
While in the example it had CRC Length = 16 bits
I tried adding radio.setCRCLength(NRF24.CRC_ENABLED) to my receive python script, but it didn't have any effect. I also tried radio.setCRCLength(NRF24.CRC_16) and that had no effect either.
Is there some magic required to
nickvans
  • 109
  • I wasn't able to figure out how to make the radio work properly using the tutorial, however I was able to make the radio work using the library here: http://tmrh20.github.io/RF24/Linux.html – nickvans Feb 19 '18 at 05:18
  • This answer fixed my issues
    In lib_nrf24.py in function:
    def begin(self, csn_pin ... after self.spidev.open add:
    `self.spidev.max_speed_hz = 4000000`
    – Jak May 13 '19 at 10:09
To finish this question I will quote the solution the questioner @nickvans has given in a comment:
  • 42,107
  • 85
  • 197
