I want to make python 3 as default in raspberry pi 3b and install scikit-learn and scikit-plot for the python 3 version. What are exact steps to be followed. Appreciate your input. Thank you
Asked
Active
Viewed 2.0k times
If you run linux command ls -l python* within the directory, you will see that python is just a symlink to python2.7, if you know linux commands well enough, you can easily make a change to link python -> python3.
One more thing you need to aware is that in order to install packages for python3, you need to run pip3. This is probably the reason that you run into the case where "No module name 'script'" error. Again, run ls -l pip* to find out more.
You can also run pip3 list to check what packages are installed for python3.
hcheung
- 845
- 7
- 14
3For many reasons, it is not a good idea to point
/usr/bin/pythontopython3. See for example https://stackoverflow.com/questions/43062608/how-to-update-alternatives-to-python-3-without-breaking-apt – Bex Aug 18 '17 at 08:52 -
@Bex, I won't recommend messing with the default installation either (which is the link that you referred to is doing). However, to put a symbolic link so that typing
pythonto launchpython3instead of the defaultpython2is a different story, and do no harm for the fundamental system installation. – hcheung Aug 18 '17 at 09:35 -
2Instead of changing the default system-wide you could change it just for your pi-user. Do this:
sudo apt install python3; mkdir ~/bin; ln -s /usr/bin/python3 ~/bin/python. Log your user out and log back in. Do this:which python, This should return/home/pi/bin/python. Now everthing under this user will use the symlink which points to python3. Delete~/bin/python, log out and back in to revert this change. – MadMike Aug 18 '17 at 11:25
make python3 as default? – Jul 10 '17 at 05:16
