I have looked at various questions but none seems to work...
I have a remote Pi that for various reasons tends to lose power occasionally and then boot back up. I don't have physical access to this thing very often so I set up an ssh tunnel to access it remotely. I need this tunnel to start when the Pi reboots so that I can always have access, even if the power goes in and out.
I have the following script create_tunnel.sh running in a cronjob (user and hostname removed obviously):
/usr/bin/ssh -i /home/user/.ssh/id_rsa -N -R 4445:localhost:22 user@hostname &
if [[ $? -eq 0 ]]; then
    echo "Tunnel to host created successfully"
else
    echo "An error occurred creating a tunnel to host. RC was $?"
fi
And here is the crontab:
@reboot /usr/local/sbin/create_tunnel.sh > /usr/local/sbin/tunnel.log
When I reboot manually, I can see in tunnel.log that the job ran:
Tue  4 Apr 13:34:27 EDT 2017
But the tunnel does not exist. And when I go to run the command manually, after the Pi has booted, the tunnel comes up fine and I can connect to it without any hassle. What's going on? Is the tunnel getting created and then later destroyed somehow?
ClydeTheGhost
  • 123
  • I have used autossh for this purpose in the past. It has a number of convenience features that might make it simpler than rolling your own with bare ssh, including keepalives and reestablishing dropped connections. – bobstro Apr 04 '17 at 19:13
You start the process in the background, which is always successful regardless the result. You should use -f switch instead, which will make the process go to background just after the connection and port forwarding is established (or failed):
/usr/bin/ssh -f -i /home/user/.ssh/id_rsa -N -R 4445:localhost:22 user@hostname
Jakuje
  • 516
    Thanks! This didn't fix the problem but it did reveal that the tunnel was not being created properly by showing the correct result in the log file. – ClydeTheGhost Apr 06 '17 at 14:32
