The following works flawlessly, in that it allows me to access a webpage hosted on the Pi at my domain which is hooked up to a google compute vm.
pi@raspberrypi:~ $ ./pi_home_reverse_proxy/scripts/establish_remote_connection.sh
Tunnel to host created successfully
pi@raspberrypi:~ $
I've attempted to make this functionality persistent by running the script 'at boot' via the usual methods (crontab, /etc/rc.local, creating a service via systemctl) and none have achieved the functionality that is achieved by running the script from the shell after boot.
I have confirmed that that various methods of scheduling at boot have indeed ran the script by including a command at the end of the script to create a file or log some details. I have focused my efforts on the systemctl service method, as this allows for waiting until the network is 'up', as outlined in the solution to this question:
Running a script after an internet connection is established
This is the service file:
[Unit]
Description=Establish Remote Connection Service
Wants=network-online.target
After=network-online.target
[Service]
Type=simple
User=pi
WorkingDirectory=/home/pi
ExecStart=/home/pi/pi_home_reverse_proxy/scripts/establish_remote_connection.sh
[Install]
WantedBy=multi-user.target
A status check on this service results in:
pi@raspberrypi:~ $ sudo systemctl status establish_remote_connection.service
● establish_remote_connection.service - Establish Remote Connection Service
Loaded: loaded (/etc/systemd/system/establish_remote_connection.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mon 2022-03-07 19:27:22 AWST; 9s ago
Process: 976 ExecStart=/home/pi/pi_home_reverse_proxy/scripts/establish_remote_connection.sh > ~/tunnel.log (code=exited, status=0/SUCCESS)
Main PID: 976 (code=exited, status=0/SUCCESS)
CPU: 118ms
Mar 07 19:27:21 raspberrypi systemd[1]: Started Establish Remote Connection Service.
Mar 07 19:27:22 raspberrypi establish_remote_connection.sh[976]: Tunnel to host created successfully
Mar 07 19:27:22 raspberrypi systemd[1]: establish_remote_connection.service: Succeeded.
The contents of the script (with the public ip/domain removed) are as follows:
#!/bin/bash
# establish_remote_connection.sh
# Establishes a remote connection with the cloud server
# intended to be run on a Raspberry Pi serving something
The IP of your running service in the cloud
export REMOTE_HOST=<vm-ip-address>
export REMOTE_HOST=<domain>
Keep this at 5000, it is configured in nginx config remotely
export REMOTE_PORT=5000
The local host of the service to forward (usually 0.0.0.0)
export LOCAL_HOST=0.0.0.0
The local port of the running service to forward
export LOCAL_PORT=3000
ssh -f -N -T -R $REMOTE_PORT:$LOCAL_HOST:$LOCAL_PORT piconnect@$REMOTE_HOST
if [[ $? -eq 0 ]]; then
echo "Tunnel to host created successfully"
else
echo "An error occurred creating a tunnel to host. RC was $?"
fi
I have followed the advice in the nearest issue I could find:
Yet it has not yielded any results.
Would be great to get to the bottom of this!
