My solution for Raspbian 8.0 (Jessie) based on logging to RAM
There already exists the Ramlog Debian package and installation instructions for this. However, this didn't work for me (Starting ramlog-tmpfs 2.0.0: Error: /var/log is in use... [fail]).
Using iotop -bktoqqq
I figured out most frequent write access. It turns out that also /var/cache/samba/ is frequently written to. So this also has to go to RAM in addition to /var/tmp/ where the new log files will be.
1. Creating the ramdisk
So first these two entry have to be added to
/etc/fstab
tmpfs /var/tmp tmpfs size=10M,nodev,nosuid 0 0
tmpfs /var/cache/samba tmpfs size=5M,nodev,nosuid 0 0
2. The log2disk script
We need to save this script in /usr/local/bin/log2disk
which will append and delete the contents from all log files in /var/tmp/log/
to the files in /var/log/
#!/bin/sh
# Author: Frank Breitling <frank.breitling@gmx.de>
DESC="Moving contents from /var/tmp/log/ to /var/log/"
if [ $(id -u) -ne 0 ]
then echo "Please run as root"
exit
fi
echo $DESC
exec >>/var/log/log2disk.log 2>&1
date
cd /var/tmp/
for i in log/*; do
basename $i
cat $i >>/var/$i
>$i
done
and make it executable sudo chmod +x /usr/local/bin/log2disk
3. Adding to crontab
We want to run this script every 3 hours and add this line to the system's /etc/crontab
10 */3 * * * root /usr/local/bin/log2disk
(Don't forget a final newline which is needed by crontab.)
4. Installing the log2disk.service
We need to create a systemd service in /lib/systemd/system/log2disk.service
that executes this script before shutdown and reboot, so that the log file contents gets preserved:
[Unit]
Description=Write log files to disk
RequiresMountsFor=/
Before=rsyslog.service
[Service]
Type=oneshot
RemainAfterExit=true
ExecStart=/bin/true
ExecStop=/usr/local/bin/log2disk
[Install]
WantedBy=multi-user.target
and install it with sudo systemctl enable log2disk
5. Selecting the log files for RAM
Now we can tell /etc/rsyslog.conf
which logfiles to keep in RAM. These files are auth.log, syslog, daemon.log, user.log and messages
and we replace for each of their entries the log/
path by tmp/log/
for example like this:
auth,authpriv.* /var/tmp/log/auth.log
Done!
After a reboot, the system will now log the most frequent log entries to /var/tmp/log
and sync them back every 3 hours and before shut down.
We can use iotop
again to find a significantly reduced write activity.
However we should not be worried about the green ACT LED flashing. Apparently this is not a good write access indicator.
shutdown now
and no more SD corruptions. – fcm Feb 26 '17 at 13:53I ran this commend to narrow it down sudo du -xh / | grep -P "G\t"
The result showed 110gb /home/pi/.cache/lxsession/LXDE-pi/ then I did ls -al
pi@ohrpi01:~ $ ls -al /home/pi/.cache/lxsession/LXDE-pi/ total 24 drwxr-xr-x 2 pi pi 4096 Jan 5 02:10 . drwxr-xr-x 3 pi pi 4096 Jan 5 02:10 .. -rw------- 1 pi pi 105876192832 Jan 5 02:13 run.log <- it looked similar to this. Just wanted to let everyone know where I found mine.
Hope this helps someone.
– nexusguy59 Jan 05 '21 at 07:26
