The green led (ACT) on my Raspberry Pi 3 is set to mmc0
to flash on SD card activity via
echo mmc0 |sudo tee /sys/class/leds/led0/trigger
However, it flashes much more often (randomly every few seconds) than it should according to
iotop -bktoqqq -d .5
and
iostat -dzp 5
So I wonder what is the light indicating if nothing is read or written to the SD card for many seconds or minutes.
Has anybody seen this LED off for longer periods in the mmc0
mode or does it always flash unrelated to SD card I/O on a Raspberry Pi 3?
It also has an mmc1
mode, in which it flashes even more frequently. I wonder what that indicates.
Why does it matter? After a colleague pointed out that Raspberries kill SD cards, I wanted to reduce my writes to my SD card in order to increase its lifetime and was expecting a less flashing LED indicating some sort of success. Now I am worried that the controller is still messing with it.
config.txt
likedtparam=act_led_trigger=heartbeat
, althoughmmc0
should be the default. Modifying the file the way you did leaves a non-standard file which would normally indicate trigger like [mmc0] (among other entries). The contents vary between Pi models. – Milliways Feb 13 '17 at 01:21iotop
andiostat
? Does your ACT behave different? – Frank Breitling Feb 13 '17 at 18:16
