When using the Raspberry Pi 3 to run a presentation in Libre Office, the screen goes blank after a while. My questions:
  1. Is there a file that I can configure/set the screen active constantly?
  2. Where are these files located? (in the root? home?)
  3. Will the changes take effect without rebooting the Raspberry Pi?
Bex
  • 2,929
  • 34
Avron
  1. Open up /etc/lightdm/lightdm.conf using your favorite text editor.
  2. Look for the line #xserver-command=X. Change it to xserver-command=X -s 0 dpms
    • It should be at line 87 if things don't change.
  3. Save and reboot.
Source
Jon Musselwhite
  • 774
The simplest answer is to install gnome-system-tools - then you will have a menu, Preferences, Screensaver program that can help you do those settings in the GUI.
SDsolar
  • 2,348
  • 43
-2
Run
sudo nano etc/kbd/config
and try changing BLANK_TIME to 0 and POWERDOWN_TIME to 0.
Save the file and then restart the process by typing
sudo /etc/init.d/kbd restart
