I'm attempting to install un-netinst
using the instructions here. My ultimate aim is to install an
Ethereum Client.
I have reformatted my 64GB SD disk to FAT32 and copied the files as instructed (using Windows7 and Macroit Partition Manager):
Link: http://ethembedded.com/wp-content/uploads/2015/06/ua-netinst-sd-card-list.png
When I power up the Pi (3 Model B V1.2), the power LED comes on but nothing else happens.
I get no signal to the monitor.
What steps should I take to debug this?
The install config file is as below:
preset=server
packages=sudo,nano,screen,dphys-swapfile,git,unzip # comma separated list of extra packages
mirror=http://mirrordirector.raspbian.org/raspbian/
release=jessie
hostname=ethpi
domainname=
rootpw=root
cdebootstrap_cmdline=
bootsize=+128M # /boot partition size as given to fdisk
rootsize= # / partition size in megabytes, leave empty to use all free space
timeserver=time.nist.gov
ip_addr=dhcp
ip_netmask=0.0.0.0
ip_broadcast=0.0.0.0
ip_gateway=0.0.0.0
ip_nameservers=
online_config= # URL to extra config that will be executed after installer-config.txt
usbroot= # set to 1 to install to first USB disk
cmdline="dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 elevator=deadline"
rootfstype=ext4
rootfs_mkfs_options=
rootfs_install_mount_options='noatime,data=writeback,nobarrier,noinit_itable'
rootfs_mount_options='errors=remount-ro,noatime'
My initial thoughts are that the FAT32 formatting is somehow incorrect. Windows indicates that the card is FAT32 formatted (RightClick->Properties). Is this enough to confirm that the format is correct?
EDIT:
I've also tried the following suggested by GitHub user 4eMaLo:
I got it to work for me by copying the boot/ directory from the official reposiory into the SD root and adding
[pi3] initramfs installer-rpi2.cpio.gz
to config.txt
Unfortunately I still get no response, aside from power on LED, from the Pi however.
