This is a synthesis of the answers above and elsewhere that worked for me - back up your image in case you make a mistake:
Firstly make the image file bigger (here we're adding 1GB to the end):
truncate -s +1G ./image.img
Next map the whole image as a loop device so we can poke at the partition table
sudo losetup /dev/loop0 ./image.img
For future reference lets dump it:
sudo fdisk -l /dev/loop0
Output looks like:
Disk /dev/loop0: 2962 MB, 2962227200 bytes
255 heads, 63 sectors/track, 360 cylinders, total 5785600 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000c4661
Device Boot Start End Blocks Id System
/dev/loop0p1 8192 122879 57344 c W95 FAT32 (LBA)
/dev/loop0p2 122880 5785599 2831360 83 Linux
Now we'll remake the last partition by deleting it, then recreating it at the same start location, same type but different end location. So make note of the "Start" column for loop0p2 (partition 2 - the Linux partition) - we'll use it later - its 122880 here.
sudo fdisk /dev/loop0
Enter the following - they are safe to enter - nothing permanent happens until you've read my explanation that follows:
p
d
n
p
just hit enter to accept the default
p
Step 1 - print current table. Steps 2-3 - delete partition 2, Steps 4-8 - recreate partition 2 with new end point (default is end of image), Step 9 - print out the new table.
Assuming your newly printed table is identical to the original table except for the End value and Blocks value (ie the size has changed) you're ready to commit.
Enter w to commit your change, then enter q to quit.
Updating here - in 2023:
You can skip this next section on most modern Linux distributions as loop devices support partitions - eg you could simply access /dev/loop0p2 instead of having to map using an offset. eg:
sudo e2fsck -f /dev/loop0p2
sudo resize2fs /dev/loop0
Resumes original text:
You can delete that loopback device, we'll make another for the second partition. Remember the start offset you noted and used above - we'll use it again:
sudo losetup -d /dev/loop0 # delete the old loop setup
sudo losetup -o $((122880*512)) /dev/loop0 ./image.img
That will create a new mapping on /dev/loop0 pointing just at partition 2 - for reference 512 is the sector-size you can see in the first fdisk output.
Now resize the partition to fill the available space:
Done - now clean up:
