Can I run FreeBSD on Raspberry Pi 3?
I also have a Raspberry Pi 1 B+ has issues booting FreeBSD: It ends up in a "mountroot" prompt.
The fine folks at RaspBSD provide an image for the Pi 3.
You can download it at RaspBSD on the RaspberryPi.
At the moment there is no out-of-the-box FreeBSD build for Raspberry Pi 3.
But they are on it (see freebsd-arm mailing list).
For your RPi 1: Try one of the recent 11.0-RC2 or 12.0-CURRENT images from https://www.freebsd.org/where.html.
They shall boot fine.
It is being little late to answer this question. But, I am answering this for someone who is or will be going to search for the same question in or after 2018, then this will help.
I have installed FreeBSD 12.0-current on my Raspberry Pi 3 with 16GB SD-CARD.
I am using USB-TTL converter to access serial console and then via minicom.
I think sshd
starts at boot but you need to setup wireless or wired connection.
Either you can use LAN cable to share internet from your PC to Raspberry Pi 3 or you can also use the simple method is just plug the wifi adapter and at the time of writing this answer I haven't checked the default built-in Broadcom wifi support.
I had even asked the question regarding with built-in wireless in 2017. Below is the response from FreeBSD community in 2017.
[prev in list] [next in list] [prev in thread] [next in thread]
List: freebsd-arm Subject: Re: Support for Raspberry Pi 3 wifi broadcom driver in FreeBSD From: Ilya Bakulin Date: 2017-06-20 9:36:17 Message-ID: 9d29575ccb57d1543ec78705bfd001b4 () bakulin ! de [Download message RAW]
Hi Neeraj,
no, wireless chip of RPi3 is not supported in FreeBSD. The support depends on the new SD/SDIO stack integration. Once it is integrated, someone has to write a driver for the chip. No ETAs on both tasks.
On 2017-06-16 06:04, Neeraj Pal wrote:
Hello all,
<p>I want to know about wireless driver support for <em>Raspberry Pi 3</em>.</p> <p>Is there any support for Raspberry Pi 3 wireless Broadcom (<em>brcmfmac</em>) driver? Because i feels difficulty to set-up wireless in Raspberry Pi 3 (installed <em>FreeBSD</em>).</p> <p>*Details :[root@rpi3 /usr/home/raspberry]# *uname -a <em>FreeBSD rpi3 12.0-CURRENT FreeBSD 12.0-CURRENT #0 r318898M: Thu May 25 15:07:15 MDT 2017 raspberry@hive.raspbsd.org:/usr/home/brd/rpi3/crochet/work/obj/arm64.aarch64/usr/src/sys/GENERIC arm64</em></p> <hr> <p>freebsd-arm@freebsd.org mailing list <a href="https://lists.freebsd.org/mailman/listinfo/freebsd-arm" rel="nofollow noreferrer">https://lists.freebsd.org/mailman/listinfo/freebsd-arm</a> To unsubscribe, send any mail to "freebsd-arm-unsubscribe@freebsd.org"</p>
-- Mit freundlichen Grüßen, Ilya Bakulin _______________________________________________ freebsd-arm@freebsd.org mailing list https://lists.freebsd.org/mailman/listinfo/freebsd-arm To unsubscribe, send any mail to "freebsd-arm-unsubscribe@freebsd.org" [prev in list] [next in list] [prev in thread] [next in thread]
Well, I am using Panda Wireless PAU07 wireless adapter.
And, by default login credentials are user:password is freebsd:freebsd and root:root.
freebsd@generic:~ % uname -a
FreeBSD generic 12.0-CURRENT FreeBSD 12.0-CURRENT #0 r335317: Mon Jun 18 17:37:04 UTC 2018 root@releng3.nyi.freebsd.org:/usr/obj/usr/src/arm64.aarch64/sys/GENERIC arm64
freebsd@generic:~ %
Here, dmesg
freebsd@generic:~ % dmesg
KDB: debugger backends: ddb
KDB: current backend: ddb
Copyright (c) 1992-2018 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)
WARNING: WITNESS option enabled, expect reduced performance.
VT: init without driver.
KLD file umodem.ko is missing dependencies
KLD file if_run.ko is missing dependencies
Starting CPU 1 (1)
Starting CPU 2 (2)
Starting CPU 3 (3)
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
random: unblocking device.
random: entropy device external interface
MAP 8000000 mode 2 pages 8
MAP 39f36000 mode 2 pages 1
MAP 3b3aa000 mode 2 pages 1
MAP 3f100000 mode 1 pages 1
kbd0 at kbdmux0
ofwbus0: <Open Firmware Device Tree>
simplebus0: <Flattened device tree simple bus> on ofwbus0
ofw_clkbus0: <OFW clocks bus> on ofwbus0
clk_fixed0: <Fixed clock> on ofw_clkbus0
clk_fixed1: <Fixed clock> on ofw_clkbus0
regfix0: <Fixed Regulator> on ofwbus0
regfix1: <Fixed Regulator> on ofwbus0
psci0: <ARM Power State Co-ordination Interface Driver> on ofwbus0
local_intc0: <BCM2836 Interrupt Controller> mem 0x40000000-0x400000ff on simplebus0
intc0: <BCM2835 Interrupt Controller> mem 0x7e00b200-0x7e00b3ff irq 20 on simplebus0
gpio0: <BCM2708/2835 GPIO controller> mem 0x7e200000-0x7e2000b3 irq 22,23 on simplebus0
gpiobus0: <OFW GPIO bus> on gpio0
generic_timer0: <ARMv7 Generic Timer> irq 0,1,2,3 on ofwbus0
Timecounter "ARM MPCore Timecounter" frequency 19200000 Hz quality 1000
Event timer "ARM MPCore Eventtimer" frequency 19200000 Hz quality 1000
bcm_dma0: <BCM2835 DMA Controller> mem 0x7e007000-0x7e007eff irq 4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19 on simplebus0
bcmwd0: <BCM2708/2835 Watchdog> mem 0x7e100000-0x7e100027 on simplebus0
bcmrng0: <Broadcom BCM2835 RNG> mem 0x7e104000-0x7e10400f on simplebus0
mbox0: <BCM2835 VideoCore Mailbox> mem 0x7e00b880-0x7e00b8bf irq 21 on simplebus0
gpioc0: <GPIO controller> on gpio0
uart0: <PrimeCell UART (PL011)> mem 0x7e201000-0x7e201fff irq 24 on simplebus0
uart0: console (115200,n,8,1)
spi0: <BCM2708/2835 SPI controller> mem 0x7e204000-0x7e204fff irq 26 on simplebus0
spibus0: <OFW SPI bus> on spi0
spibus0: <unknown card> at cs 0 mode 0
spibus0: <unknown card> at cs 1 mode 0
iichb0: <BCM2708/2835 BSC controller> mem 0x7e804000-0x7e804fff irq 37 on simplebus0
bcm283x_dwcotg0: <DWC OTG 2.0 integrated USB controller (bcm283x)> mem 0x7e980000-0x7e98ffff,0x7e006000-0x7e006fff irq 43,44 on simplebus0
usbus0 on bcm283x_dwcotg0
sdhci_bcm0: <Broadcom 2708 SDHCI controller> mem 0x7e300000-0x7e3000ff irq 46 on simplebus0
mmc0: <MMC/SD bus> on sdhci_bcm0
fb0: <BCM2835 VT framebuffer driver> on simplebus0
fbd0 on fb0
VT: initialize with new VT driver "fb".
fb0: 656x416(656x416@0,0) 24bpp
fb0: fbswap: 1, pitch 1968, base 0x3eb33000, screen_size 818688
pmu0: <Performance Monitoring Unit> irq 50 on simplebus0
cpulist0: <Open Firmware CPU Group> on ofwbus0
cpu0: <Open Firmware CPU> on cpulist0
cpu1: <Open Firmware CPU> on cpulist0
cpu2: <Open Firmware CPU> on cpulist0
cpu3: <Open Firmware CPU> on cpulist0
gpioled0: <GPIO LEDs> on ofwbus0
gpioled0: <led0> failed to map pin
gpioled0: <led1> failed to map pin
cryptosoft0: <software crypto>
Timecounters tick every 1.000 msec
usbus0: 480Mbps High Speed USB v2.0
iicbus0: <OFW I2C bus> on iichb0
iic0: <I2C generic I/O> on iicbus0
ugen0.1: <DWCOTG OTG Root HUB> at usbus0
uhub0: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
mmcsd0: 16GB <SDHC USD00 0.2 SN 3AC34AE0 MFG 02/2016 by 156 SO> at mmc0 50.0MHz/4bit/65535-block
Release APs...done
CPU 0: ARM Cortex-A53 r0p4 affinity: 0
Instruction Set Attributes 0 = <Trying to mount root from ufs:/dev/ufs/rootfs [rw]...
CRC32>
Instruction Set Attributes 1 = <>
Processor Features 0 = <AdvSIMD,Float,EL3 32,EL2 32,EL1 32,EL0 32>
Processor Features 1 = <0>
Memory Model Features 0 = <4k Granule,64k Granule,MixedEndian,S/NS Mem,16bit ASID,1TB PA>
Memory Model Features 1 = <>
Memory Model Features 2 = <32b CCIDX,48b VA>
Debug Features 0 = <2 CTX Breakpoints,4 Watchpoints,6 Breakpoints,PMUv3,Debug v8>
Debug Features 1 = <0>
Auxiliary Features 0 = <0>
Auxiliary Features 1 = <0>
CPU 1: ARM Cortex-A53 r0p4 affinity: 1
CPU 2: ARM Cortex-A53 r0p4 affinity: 2
CPU 3: ARM Cortex-A53 r0p4 affinity: 3
Warning: no time-of-day clock registered, system time will not be set accurately
uhub0: 1 port with 1 removable, self powered
ugen0.2: <vendor 0x0424 product 0x9514> at usbus0
uhub1 on uhub0
uhub1: <vendor 0x0424 product 0x9514, class 9/0, rev 2.00/2.00, addr 2> on usbus0
uhub1: MTT enabled
uhub1: 5 ports with 4 removable, self powered
ugen0.3: <vendor 0x0424 product 0xec00> at usbus0
smsc0 on uhub1
smsc0: <vendor 0x0424 product 0xec00, rev 2.00/2.00, addr 3> on usbus0
smsc0: chip 0xec00, rev. 0002
miibus0: <MII bus> on smsc0
smscphy0: <SMC LAN8700 10/100 interface> PHY 1 on miibus0
smscphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
ue0: <USB Ethernet> on smsc0
ue0: Ethernet address: b8:27:eb:b5:5b:d2
ugen0.4: <Ralink 802.11 n WLAN> at usbus0
lo0: link state changed to UP
ue0: link state changed to DOWN
run0 on uhub1
run0: <1.0> on usbus0
run0: MAC/BBP RT5592 (rev 0x0222), RF RT5592 (MIMO 2T2R), address 9c:ef:d5:fe:18:45
ieee80211_load_module: load the wlan_amrr module by hand for now.
wlan0: Ethernet address: 9c:ef:d5:fe:18:45
run0: firmware RT3071 ver. 0.33 loaded
wlan0: link state changed to UP
freebsd@generic:~ %
And, I am not sure about Raspberry Pi 1 because I don't have that. But, I think currently all supports.
Take a look at the last answer to this question: FreeBSD - easiest way to install on my RPi? it is pretty easy these days, I have it running on all of the "big" boards (version 1 through 3) in my collection, I suspect that it would run on a Zero as well, but I don't have one to try.
