I don't have a screen for my Raspberry Pi. I want to SSH into it, but I get Connection Refused, so I presume SSH is not enabled.
As advised in other questions I have looked at enabling the boot_enable_ssh.rc script on the sd card. However I don't have a boot directory in my OS (or it is not visible via the card reader in my iMac) - 2012-12-16-wheezy-raspbian.img.
I have also tried issuing the following commands via a usb keyboard:
pi [enter]
raspberry [enter]
sudo /etc/init.d/ssh start [enter]
raspberry [enter]
But this hasn't worked. Now in some docs I see that raspi-config is the first thing to come on a newly booted RPi. Could someone tell me the keystrokes to enable SSH via raspi-config please? Or if I am on the wrong track, please advise. Thanks.
EDIT: In trying to follow this advice https://raspberrypi.stackexchange.com/a/1706/4373 I am not seeing an etc directory when mounting the SD card on my iMac. If I run ls from the terminal I only get the following:
bootcode.bin fixup.dat kernel.img start.elf
cmdline.txt fixup_cd.dat kernel_cutdown.img start_cd.elf
config.txt issue.txt kernel_emergency.img
Have I screwed up the imaging of the SD card?
sudo raspi-config) where you can enable SSH. To see that, maybe you could follow the steps shown in this video: http://www.youtube.com/watch?v=nXvODj6YpAE ? I know it is a bit primitive approach, but I thought I would mention it :) – Lasse Christiansen Jan 11 '13 at 11:52
