I am unable to connect with my Pi on ssh, with the following error returned:
FAIL: Read from socket failed
I do not have a screen to connect to the Pi. Can I fix this problem by editing data on the SD card on my PC? The OS is Raspbian, and the model is a Raspberry Pi B.
Here is the debug log:
[SSH] OpenSSH_5.6, OpenSSL 1.0.0a 1 Jun 2010 cancel)...
[SSH] debug:
[SSH] Connecting to 192.168.0.105 [192.168.0.105] port 22.
[SSH] debug:
[SSH] successful connection (select got writefds).
[SSH] debug:
[SSH] Connection established.
[SSH] debug:
[SSH] permanently_set_uid: 0/0
[SSH] debug:
[SSH] Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-4+deb7u1
[SSH] debug:
[SSH] match: OpenSSH_6.0p1 Debian-4+deb7u1 pat OpenSSH*
[SSH] debug:
[SSH] Enabling compatibility mode for protocol 2.0
[SSH] debug:
[SSH] Local version string SSH-2.0-OpenSSH_5.6
[SSH] Server Version OpenSSH_6.0p1 Debian-4+deb7u1
[SSH] debug:
[SSH] packet_start[20]
[SSH] debug:
[SSH] send: len 904 (includes padlen 4)
[SSH] debug:
[SSH] packet_send done
[SSH] debug:
[SSH] SSH2_MSG_KEXINIT sent
[SSH] debug:
[SSH] packet_read()
[SSH] FAIL: Connection closed by 192.168.0.105
[SSH] debug:
[SSH] dev_main Unnormal end of SSHThread (longjmp was triggered)
[SSH] debug:
[SSH] platform_shutdown(576, 2)
[SSH] debug:
[SSH] platform_close 576
[SSH] INFO: DISCONNECT
After updating the OpenSSH server, here is the new event log:
OpenSSH_6.0p1 Debian-4, OpenSSL 1.0.1e 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.0.105 [192.168.0.105] port 22.
debug1: Connection established.
debug1: identity file /home/me/.ssh/id_rsa type -1
debug1: identity file /home/me/.ssh/id_rsa-cert type -1
debug1: identity file /home/me/.ssh/id_dsa type -1
debug1: identity file /home/me/.ssh/id_dsa-cert type -1
debug1: identity file /home/me/.ssh/id_ecdsa type -1
debug1: identity file /home/me/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian- 4+deb7u1
debug1: match: OpenSSH_6.0p1 Debian-4+deb7u1 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.0p1 Debian-4
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
Read from socket failed: Connection reset by peer
ssh <RPi's IP address> -v
? (make sure to hide sensitive data) – Morgan Courbet Sep 25 '14 at 08:47ssh <RPi's IP address> -vvv
and paste the log? – Morgan Courbet Sep 25 '14 at 12:14-vvv
command also aren't so helpful. it is almost the same – Undrooleek Sep 25 '14 at 12:44
