Good day While looking for the smallest possible GPS solution for a Raspberry PI 2 searching has brought me to these solutions.
I am thinking of getting those two, but being more of a programmer than an hardware person I was thinking I would need some help connecting them to my Pi.
In this Post How do I attach a GPS receiver?. @ppumpkin mentioned that this can be connected to the Pi using the UART pins. ( I have male to female breadboard wire so I can do that)
However in the Datasheet for this device. The 6 pins are described as this
1 GND Ground, 2 VCC V Power Supply, 3 DP USB Positive, 4 DM USB Negative ,5 V_Bat Backup power,6 PWR_CTRL
So apart from pin 1 GND of the GPS being connected to the Pi's ground. I'm not exactly sure where the remaining 5 Pins should be connected.
P.S will the Lat/Lon be returned in such a way where I can save it to a variable and pass it to a URL or whatever I decide I want to do with it?
Thank for any assistance or any resource which can help me.
Niana
  • 127
The SparkFun site says
Note: We are carrying the “T” option of this module which is TTL-UART and not USB.
That is connected as follows.
GPS                 Pi
UART                Pin
TTL
1 Ground     ---    6 Ground
2 VCC (3.3V) ---    1 3V3
3 TXA        ---   10 RXD
4 RXA        ---    8 TXD
5 V_BAT      ---    No connection
6 PWR_CTRL   ---    No connection
joan
  • 71,024
  • 73
  • 106
  • Thanks for this answer. However I'm looking at it and would like some clarification, should pin 3 (TXA) on the UART go to pin 10 (RXD) and pin 4 (RXA) go to pin 8 (TXD). – Niana Mar 10 '16 at 12:28
  • Yes, it's usual for serial links to connect one ends TX to the other ends RX and vice versa. The datasheet says "3 TXA Port A serial data output (from GPS) Output" which must be connected to the Pi's RXD pin. – joan Mar 10 '16 at 12:36
