This is the tightvncserver init.d script, tightvncserver, in /etc/init.d
### BEGIN INIT INFO
# Provides: tightvncserver
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: tightvncserver starts at boot time
# Description: Start tightvncserver connection service
### END INIT INFO
# set the USER variable for the VNC server
# Note: Starting the VNC Server on :1 means we need to connect to port 5901
# To install:
# sudo chown root:root /etc/init.d/tightvncserver
# sudo chmod 755 /etc/init.d/tightvncserver
# sudo update-rc.d tightvncserver defaults
export USER=pi
export HOME=/home/pi
eval cd ~$USER
case "$1" in
start)
su - $USER -c "/usr/bin/tightvncserver -geometry 1280x720 -depth 24 :1"
echo "Starting TightVNC server for $USER"
stop)
pkill Xtightvnc
echo "TightVNC server stopped"
echo "Usage: /etc/init.d/tightvncserver {start|stop}"
exit 1
esac
exit 0
Here is the ls -l:
-rwxr-xr-x 1 root root 918 Dec 13 14:02 tightvncserver
It will run when I type at the command prompt:
sudo ./tightvncserver start
But it does not run at boot time. I have done the command:
Can anyone explain what is wrong?
start
command. I get following errorJob for vncserver@1.service failed. See 'systemctl status vncserver@1.service' and 'journalctl -xn' for details.
. Here's gist of those command's errors.. Thanks – giri-sh Dec 27 '15 at 07:00
