I have a Pi (with Raspbmc installed on it) connected to an LG TV. I disabled the CEC options in XBMC related to turning the TV on/off. However, the Pi keeps turning the TV on when rebooting. I can confirm it's the Pi and not XBMC as the TV comes on before XBMC loads. Is there any way to prevent Pi from turning the TV on? I understand that it sends a signal through HDMI when it comes on, but does it send a "wake up" signal? If so, is there any way to prevent it? It's not fun to come back from work or to wake up and see the TV's been on for hours... Thanks!
Asked
Active
Viewed 1.7k times
19
Try editing /boot/config.txt to include the line
hdmi_ignore_cec_init=1
If you're using OpenElec, the file is /flash/config.txt
More info on config.txt options can be found on the elinux wiki pages
John
- 206
- 2
- 2
damned for me, this option doesn't change anything with my bravia ... – Overnuts Sep 18 '14 at 08:16
I had to mount /boot as rw in order to do, similar to wiki.openelec.tv/index.php/Config.txt#Editing_config.txt – rebelliard Feb 20 '17 at 17:38
Preferences > System > Input Devices > Peripherals > CEC Adapter Settings Uncheck the option: "Switch source to this device on startup"
Mikheil Chikhladze
- 31
Solution 1. Disable turning TV on on boot and keep CEC adapter active.
- Put the following line into the
/boot/config.txthdmi_ignore_cec_init=1 - Update the following Kodi settings in the
Settings > System > Input > Peripherals > CEC AdapterSwitch source to this device on startup = off Devices to power on during startup = None Wake device when deactivating the screensaver = off - Turn TV off manually
- Reboot Raspberry
Result: TV is off after Raspberry reboot
Solution 2. Disable turning TV on on boot by disabling CEC adapter.
/boot/config.txthdmi_ignore_cec=1 - Turn TV off manually
- Reboot Raspberry
Raspbian 10 (buster)
Kodi 18.5
Yurii Tvardyi
- 11
