My Pi is connected to my TVs usb port which works great and I use the TV remote to control it - which I also enjoy.
The problem is whenever I turn on my TV, the pi changes the TV input source even though I don't want it to.
Is there a way to keep hcmi-cec enabled without it automatically controlling the source on the TV?
thanks
Krzysztof Adamski
  • 9,615
  • 37
  • 53
user6685
  • Can you explain further? You're powering your pi through the TV's usb port? Which source is being changed - the video? – phalt Mar 30 '13 at 10:22
  • The Pi is physically changing the source on my tv to display the output of the Pi on my tv. – user6685 Mar 31 '13 at 01:22
  • Did you find a solution for this? (Prevent XBMC from starting your TV via HDMI on (re-)start) – Stefan May 07 '13 at 09:43
In addition to @Krzystof 's excellent answer, I would quote what I read in this post:
Include the hdmi_ignore_cec_init=1 switch in /boot/config.txt.
Then in Settings>System>Input devices>Peripherals>CEC turn off the option: "Make XBMC the active source at start".
syb0rg
  • 8,188
  • 37
  • 51
ermannob
  • 161
  • I had to mount /boot as rw in order to do, similar to http://wiki.openelec.tv/index.php/Config.txt#Editing_config.txt – rebelliard Feb 20 '17 at 17:36
You can try adding hdmi_ignore_cec_init=1 config option to your /boot/config.txt. It should, in theory, disable sending initial active source message by RaspberryPi which is probably responsible for changing input source to HDMI in your case.
Krzysztof Adamski
  • 9,615
  • 37
  • 53
  • thanks Krzysztof that worked great for the Pi itself, now xbmc seems to be changing the hdmi source as well. is there a way to turn it off from within xbmc? – user6685 Mar 31 '13 at 01:35
  • I don't use XBMC so I can't test it but there should be an option in XBMC settings to disable this. It should be called Power on TV when starting XBMC or similar. – Krzysztof Adamski Apr 01 '13 at 09:13
