I've bought a wifi adapter for raspberry pi, I don't have an OS, I'm running RetroPie so I need a console solution.
Someone suggested accessing:
sudo nano /etc/network/interfaces
and changing it to:
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
    wpa-ssid "ssid"
    wpa-psk "password"
I then reset my device like told and inserted the wifi adapter.
After booting up I don't know what else to do now to connect with wifi...
Any ideas?
SaturnsEye
  • 295
This applies to Raspbian Wheezy prior to 2015-05-05 for later (and Jessie) See How do I set up networking/WiFi/Static IP
You can do this but I would suggest /etc/network/interfaces
auto lo
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
iface home inet dhcp
iface default inet dhcp
And put network in /etc/wpa_supplicant/wpa_supplicant.conf Mine is:-
update_config=1
network={
    scan_ssid=1
    ssid="*****"
    psk="*****"
    id_str="home"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    eap=MD5
You may need to customise settings depending on your WiFi. Check out man wpa_supplicant.conf
