I'm having some trouble with my pi. I'm using ssh connection only - through cable but I bought WiFi USB adapter so I can also connect my pi from my tablet. Unfortunately when I reconfigured interfaces(in /etc/network/interfaces) and rebooted pi, I couldn't connect to it as usual - through cable but the led on my WiFi USB stick was blinking. Then I tried a lot of configurations but none of them worked properly :/
What I want to have: -static eth0 address -static wlan0 address -possibility to connect with SSH through both eth0 and wlan0
Here's my /etc/network/interfaces at the moment:
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.137.85
netmask 255.255.255.0
gateway 192.168.137.1
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "MySSID"
wpa-psk "SuperSecretPassword"
iface default inet dhcp
And it's working for eth0 connection but not for wlan0. And led on my WiFi adapter isn't blinking even if I turn the GUI on, the program can't see this adapter - yes, drivers are installed, yes - when I check lsusb I can see it, yes - when I check lsmod I can see the module(used by 0)
Please help me, I'm a noob in RPi and don't know what to do :/
P.S. I'm running Raspbian
urban07
You may eventually make your config work, but I suggest you start with the standard configuration. See https://raspberrypi.stackexchange.com/a/23373/8697 for an example.
You can if you REALLY need to set static IP addresses, but if you have a router use DHCP. If necessary reserve addresses in your router, but get wireless working with DHCP first.
  • Hm, I think that static IP for wlan0 is not necessary, But I need it for eth0 for sure. I'll try the idea from Your link Thanks for reply :) – urban07 Dec 26 '14 at 10:06
  • Wow, it seems to be working - I can connect with putty to eth0 SSH AND WiFi is working - thank You very much :D – urban07 Dec 26 '14 at 10:23
  • But unfortunately I can't connect to it with SSH client on my android device through WiFi. What should I do to fix it? (It says: "No route to host" - rpi is connected to my home network) – urban07 Dec 26 '14 at 10:24
  • Nevermind, after reconnecting everything is just fine. Thanks for help! – urban07 Dec 26 '14 at 10:30
