I have a problem with a brand new installation of Raspbian on a Pi 3 B+ (as well as on a Pi 4, with a stock install of Openhabian), one that has already come up several times. I have tried the solutions listed in those answers, modifying /etc/network/interfaces
, but it didn't seem to help in the slightest - unless I have the Ethernet cable plugged in, the WiFi can't even get an IP, and with the cable connected, it's a crapshoot whether it gets a 169.254.x.x
IP or a proper 10.0.x.x
IP.
Contents of my interfaces config:
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa_supplicant.conf
has the correct data for connecting to the network in question:
update_config=1
network={
ssid="SkyNet"
psk="/snip/"
key_mgmt=WPA-PSK
Additionally, it looks like while I can SSH into the device from the local network, the device can't communicate out towards the wider internet. The routing table doesn't show any obvious anomalies, though:
root@panel:/home/raspbian# ip route
default via 10.0.0.1 dev wlan0
default via 192.168.0.1 dev eth0 proto dhcp src 192.168.0.51 metric 202
default via 10.0.0.1 dev wlan0 proto dhcp src 10.0.10.10 metric 303
10.0.0.0/16 dev wlan0 proto dhcp scope link src 10.0.10.10 metric 303
192.168.0.0/24 dev eth0 proto dhcp scope link src 192.168.0.51 metric 202
Anyone have any ideas what I might be doing wrong?
country=XX
(with the correct country code) sorfkill
is probably disallowing connections. – Dougie Apr 24 '23 at 10:07country=XX
key to thewpa_supplicant.conf
even if you specify it before writing the image... – Zalán Meggyesi Apr 25 '23 at 12:52
