I have the following problem.
I want to have access on my Raspberry Pi 3 via WiFi. I have once set it up using the GUI, but now running it in the headless mode. The problem now is that this works for about 3 days then I can't connect to the Pi anymore.
I found out what I then need to do is to plug in the ethernet cable and then it works again. I have also seen that there are two default routes installed. One goes over wlan0
and the other over eth0
Kernel IP routing table
default 192.168.0.1 0.0.0.0 UG 202 0 0 eth0
default 192.168.0.1 0.0.0.0 UG 303 0 0 wlan0
192.168.0.0 * 255.255.255.0 U 202 0 0 eth0
192.168.0.0 * 255.255.255.0 U 303 0 0 wlan0
So I assume that once I plug out the ethernet cable, the outgoing connections try to go over eth0
instead of wlan0
. When I then delete the entries for eth0
, WiFi works again but only for around 3 days, then all starts over again.
The following are my configuration files for the /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
and the /etc/wpa_supplicant/wpa_supplicant.conf
country=CH
update_config=1
network={
ssid="SSID"
psk=HashedPassword
Any ideas on that? Thanks
PS: I know that there is another question related to this, but that approach did not help me.
