Back again with the same issue (previously it was 5.4.51 -> 5.4.83 Kernel version does not update when using apt update, apt full-upgrade, got no useful suggestions) - now it's 5.4.83 -> 5.10.17. This is the moving from the 2nd latest RaspberryPiOS(c) release to the latest RaspberryPiOS release.
Last time I ended up installing 5.4.83 fresh after börking the 5.4.51 trying to update linux on 2 Rpi's (2B and 3B) that are setup the same. I assume most people aren't having this issue since updating an OS shouldn't be this hard, even if it is Linux. I can get to 5.10.17 if I do a clean reinstall, but that's no way to live.
The obvious maneuver:
sudo reboot
sudo apt update
sudo apt full-upgrade
sudo reboot
Doesn't lead to an update:
Linux wiipii 5.4.83-v7+ #1379 SMP Mon Dec 14 13:08:57 GMT 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Mar 29 23:19:32 2021 from 192.168.1.2
dmptrk@wiipii:~ $ sudo apt update
[sudo] password for dmptrk:
Hit:1 http://packages.microsoft.com/repos/code stable InRelease
Hit:2 http://archive.raspbian.org/raspbian testing InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:5 http://packages.azlux.fr/debian buster InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
dmptrk@wiipii:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Last time I tried rpi-update and that bjorked the 3B, and deleting the kernel-related entries in sudo nano /var/lib/dpkg/status and then refreshing it and updating from there bonked the 2B. The SD cards are fine, the hardware is fine, if I wipe it and flash to 5.10.17 right now it'll work and I'll just have to set it all up again.
What can I do to update my rpis? What am I doing that's making it not work? I gotta be doing something to muck this up - but I'm not sure what or how to see what's going wrong.
Note I have Hit:2 http://archive.raspbian.org/raspbian testing InRelease as a repo to hit from adding Wireguard support per https://www.sigmdel.ca/michel/ha/wireguard/wireguard_02_en.html 's
echo "deb http://archive.raspbian.org/raspbian testing main" | sudo tee --append /etc/apt/sources.list.d/testing.list
printf 'Package: *\nPin: release a=testing\nPin-Priority: 50\n' | sudo tee --append /etc/apt/preferences.d/limit-testing
The lower priority means it doesn't supersede anything that's in other repos, so it effects Wireguard and that's it. I understand 5.10 comes with Wireguard in the kernel and that'll be a great thing to deal with after updating to 5.10.
